69CST4x4SWB |
09-07-2016 03:42 AM |
Re: Won't shift into 4 wheel high!
Originally Posted by '63GENIII
(Post 7687660)
Welcome back. I have no idea what your t case is but I would start by finding out what kind of oil it uses and change that first. Note the condition of oil that you drain out. I had a T221 that was a stubborn shifter. Linkage looked good but for some reason would not be able to shift unless I got under the truck and used a small pry bar. The shift shafts would move very easily from underneath. If it has detent balls and springs that can be easily removed like on a 205, Id pull them out and see if it shifts easier with the detents pulled. If it does, clean and grease the detents. Thats all I can think of for now without pulling the case out.
Ive since swapped in a 205 and plan on cable shifting it. Got tired of messing with the Rockwell.
Thanks! Mines a 205. It almost feels like a bent shifting fork. Like it's right there of going in gear but not quite. I spray lubed the crap out of the linkage with no change! You have some good ideas to try when I get time to. Thanks
