Re: 67-72 frame conversion for 63 Knee Knocker Cab and Bed
I have done this frame swap over a dozen times...
:) if you are doing 1/2 ton to 1/2 ton, one of the holes on the cab mount brackets line up. :5150: |
:smoke: 1- the frame horns are 1" lower and have a different profile on the end. 2- the core support perches (brackets) are different and located wrong for the 63-66 core support 3- the rear cab mount perches. (brackets) The 67-72 rear cab mount perches are too low and the hole is in the wrong place for the 60-66 cab 4- the addition of the radiator support member is required unless the 60-62 radiator that bolts to the core support is used.. ;) The front cab perches and nearly everything else on the 63-72 frames is the same. :metal: Change out the rear cab perches and the core support perches, address how the radiator will mount and make some bumper brackets from some old 63-66 frame horns and it's a done deal and no welding required.. :metal: :5150: |
2 Attachment(s)
Here are a couple photos of a 66 that I am doing for a friend, sitting on a 68 chassis..
I just bought a 68 swb frame to do mine with thanks for all the input
