Transmission? Poor acceleration.
Ok, I guess I'm ready to hear what I don't want to hear. Here's the story:
Had someone helping me to change the oil in my 72 C20. Turns out they drained the transmission and then added 4 quarts of oil to the engine. I drove it about 10 miles then started to feel a lack of acceleration. Got it back home and figured out what happened, so I refilled the transmission and changed the oil. Problem is I'm still having acceleration problems. What's the chance the transmission isn't damaged and not in need of repair? If not a transmission problem, what do you guys think? Edit: I used Dex/Merc transmission fluid to refill. |
Re: Transmission? Poor acceleration.
Draining the transmission pan then driving the truck around will smoke a transmission in a hurry!!!!
Guessing this is a TH350 as it's one of the few GM units to have a factory drain plug you can actually remove without a fight. |
Yes. The tranny pan has the drain in its front/center.
Is there any hope for the tranny? It still moves the truck, and can accelerate, but it's not nearly as strong as it was.:barf: |
Your trans is toast. I burned up a couple th350's when they were only a qt low. I lost a trans line once and th350 was toast in 1/2 mile. I have never had a th350 with a drain plug. That would be handy sometimes but not this time. Th400's are much more forgiving on being low on fluid but not the th350's. Sad story.
I'll crawl under it today to see if I can identify the transmission. I don't know that it is a th350 or not. I bought the truck from someone who bought it from someone who married an engine and transmission to a neglected shell. I was given no information about the engine or transmission, and I'm not much of a gearhead. I am able to work on my vehicles, but I'm definitely not real knowledgable.
Right now the truck accelerates decently from a stop (although not like it did), but the lack of acceleration is really noticeable in higher gears. |
More than likely friction clutches burnt causing them to slip.
I've seen used TH350's -at least in this area -for $150-$300. I'd probably consider a rebuilt one before a used one these days but in the past I have installed used ones from running vehicles and had good luck. |
If they drained a full 4 or 5 quarts out of the transmission, I'm surprised that the truck was even able to move at all, let alone drive it down the road for any distance. I've had them just a couple quarts low and they would take a good 10-15 seconds just to jump into gear.
Well, it is a TH350. Sucks, but I guess I have to give in and believe the truth. :censored:
Pull the drain plug again and see what the oil looks like. Could pull the pan also and have a look see
Oil looks good. I drained a bit tonight because it was a tad too high.
What am I looking for when I take off the pan? |
that transmission will quit moving somewhere around 3 qts low. how were you able to drive it 10 miles with it 4 qts low?
No idea. But it took a full jug of fluid to refill.
Nothing wrong with the TH350 for regular driving and light hauling. Tons of cars and trucks had them in late 60's thru early 80's. Unless you want to upgrade to a newer one or intend to run it hard, rebuilding yours may not be a bad idea.
How are you checking the trans fluid level on the dipstick? Engine running or not?
Yes, checking the fluid level with the engine running and at normal operating temperature.
The truck still moves, just not much acceleration. I'll be driving the Camaro for the next month or so. Oh well, it could be worse.
That being said, it's been sitting except for me taking it "around the block" a few times to assess the situation. |
One more time. Does the motor rev up when you give it the gas? If not you may have a motor problem and not a trans problem.
I'll go fire it up and see how high the rpms go.
I don't have a tach, so I don't know the rpms for certain. It doesn't seem to be hitting real high rpms though. If true, any ideas? What might have happened while there was waaaaaay too much oil in the block? |
I see where having way too much can cause the rear main seal to blow, but I don't have any leaking oil on the driveway.
When is the last time the motor got a new set of plugs? If the trucks been sitting for any length of time before the mishap, maybe bad fuel and or a clogged fuel filter? Also, over filling the crankcase can lead to fouled plugs. Might take a look at the wires and caps on the distributor making sure they're all fully pressed on to the terminals. It's easy to inadvertently pull a wire loose when pulling the transmission fluid dip stick. I'd definitely install a new set of plugs before I gave up on the transmission. The fact that the 350 turbo is still pulling the truck is testament to how tough they actually are. If you did fry the clutches there should be some tell tale indicators such as a burnt smell in the fluid as well as suspended clutch material in the fluid causing it to be a bit darker than the bright red translucent fluid that was added. If the poor acceleration proves to be some fouled plugs, I'd buy the tranny a pint of this, http://www.lubegard.com/~/C-303/LUBE...uid+Protectant and myself a six pack of these, http://www.binnys.com/beer/Bud_Light...num_40500.html ;)
This truck has been my daily driver...I only commute about 5 miles round-trip. I changed the plugs a week ago, changed the air filter, and reset the timing. I don't smell anything burnt when the truck runs, but it does have some white/gray smoke coming out of the exhaust pipes. I'm definitely down with the second link you provided, but I already have put Bar's Leak into the transmission fluid to help with any slipping.
When the weather dries out a bit I'm going to crawl under the truck and drain the tranny again, then drop the pan to see what's what. That way at least I'll know if there is metal shavings or not. How would I go about "drying out" the block (removing the excess oil that may have been pushed into unwanted areas)? Where all do I look for issues? |
I agree with others, if trans was slipping, you hear the engine rev up but the truck won't accelerate. From your description, engine isn't even revving. So... let's reset.
What have you changed since the incident? Oil, spark plugs, timing. OK. Anything else? Excess oil in the engine probably didn't hurt anything as long as you drained it and refilled it to the proper level since then. If the cylinders were washed out, you may need to burn it out of the cylinders, which should have happened with a few drives already. Did you pop off your PCV hoses and make sure they aren't full of oil? Otherwise there really isn't anything else that would worry me. The spark plug change and timing change does concern me. What gap did you use on the new plugs? Do you have HEI? Did you make sure you didn't accidentally swap any plug wires? Recheck the firing order. How did you check timing? Did you make sure vacuum advance was unhooked and plugged? What timing values did you end up on? |
Changed the PCV valve today. It was sludgy and didn't rattle when shaken. I then ran the truck for about 20 minutes and kept watch on the white/gray smoke coming from the exhaust (trying to burn off any excess oil that my have blown by while over-filled). After the white/gray smoke greatly diminished, I took the truck for a spin "around the block" (actually about a 3 mile loop). I don't seem to be having transmission troubles, at least no noise and/or clunky shifts. And, I still don't have any oil leaks that would indicate a main seal issue.
When I replaced the plugs, I did so one by one...remove plug wire, remove plug, insert plug, replace plug wire. I did not gap the plugs...I used them straight out of the box. It is HEI and when I reset the timing I did so with the vacuum advance unhooked and plugged and advanced to 12. I chose to reset the timing as I was getting some backfire upon deceleration...there is no backfire now after the reset. The fluid in the tranny appears to be fine...not dark, although I haven't yet dropped the pan to see if there is any metal shavings in there. *A bit of additional info...the truck will currently not spin its tires from a stop if traveling in a straight line, but it does have enough power to spin them when leaving a stop and turning onto another road. **Another bit of additional info...I believe the engine to be a 350, but I can't be sure. I bought it from a guy who bought it from a guy...that guy supposedly built engines for racing and threw this one into this truck when the person he built it for didn't pay. The guy I got it from couldn't remember or didn't know what block was in it, and had no idea if it had been bored at all or what year. I haven't crawled back into it to take the numbers off the block. It may be a later 70's block, but I do believe it is a 350...just not certain that it's still a 350. With that information, what would you suggest the plugs be gapped to? |
It sounds like you may have dodged a bullet here if you are still moving. Maybe the extra oil in the engine was doing something but I have no idea what. The plugs should be .045".
Ok. So gapped the plugs to .045, checked the fluid levels again and tranny was fine but the engine oil was dark. That surprised me since I'd not driven the truck more than 10 miles since changing it last. So I drained and replaced that. Then ran the engine for a while and now I'm hearing a "tingy" clunk when I change between Drive and Reverse and vice versa.
That could be a u-joint in your driveshaft.
Is that possibly due to the issues I've been dealing with or separate?
Let me rephrase.
Could the u-joint be causing the loss of power/acceleration? Could the u-joint beginning to fail be caused from the other issues I've been dealing with? I don't doubt that the u-joint needs to be replaced, and will do so. |
I am amazed that a TH350 moved with a "FULL JUG" low event....now you are chasing a U joint ? How is reverse engagement ? Slow ? accel OK in reverse ? U-Joints will make noises and cause vibration but not poor accel.... very interesting post...have to hang in here to see this one fixed...
Reverse and Drive both engage fine. They don't delay but as I've stated, the truck lacks power and acceleration. But I did start to notice a "clunk" when shifting between the two. I'm getting an aftermarket tach to install later today, so hopefully I will be able to have more information about how the engine is operating.
It is possible that all of your power testing of engine and transmission could have moved a u-joint from the needs replacing in a couple of years category to needs replacing soon. It is also possible that since you are now listening to your truck closely, you noticed a noise it has been making for years. I had a drive shaft that made the tingy-clunk noise for years before the drive shaft started vibrating due to bad u-joint. Still clunks once in a while during a R-D switch due to a 40 year old drive train on its 3rd set of 100,000 miles.
Got the tach hooked up and calibrated for 8 cylinders. Ran the engine to check the rpm and would not push past 6000.
Just kidding. The LT1 in my Z28 redlines at 5800. That's not a Ferrari you're driving. I think you're expecting way too much of your engine. Trucks like torque and they like it down low. Most of your driving should probably not go much over 3500 RPM. |
I figured I'd be able to get closer to 7000 just sitting in the driveway...idk.:confused:
Maybe it's a fuel issue...I'll put a new filter in and then check the pump. |
