Drop Spindles For C20
Do they make drop spindles for the 63 C20? I haven't been able to find any to use without a conversion. I was just going to run the drum brakes and 8 lugs.
Re: Drop Spindles For C20
No drop spindles are available for any drum brakes, regardless of lug pattern. POL does make a C20 drop spindle that uses 8 lug disc brakes.
Thank you! I want to drop my front end maybe 4"-6". Looking at my options. |
Find a half ton front subframe and convert to 5 or 6 lug. Way better wheel options.
That's what I did with my C20 and it was worth every penny of it! |
Well you didn't say if you wanted to convert to 5 or 6 lug and disc brakes. Early Classic Enterprise makes a C20 to C10 conversion spindles. This allows you to keep all of your C20 parts (ball joints, tie rods, A arms, etc.) but mount the 5 or 6 lug rotor for a C10 setup.
Downside is your bolt pattern will not match front to rear. Rear would require an axle swap. POL does make a C20 drop spindle that will allow you to use disc brakes (8 lug). |
So now I'm exploring my options. I don't mind if the lug pattern is different. I'm putting dually's on the back with a smaller wheel up front so I won't carry a spare. I have a great trade out deal with a local tow company. haha It's kind of a gimmick truck anyway. I'll drive it a mile to work most days so it can sit in front and advertise my shop and use it for events. |
Either swap in a C10 front end and swap the rear end. I picked up the drop spindles from ECE to get 2.5", and converting to 5x5 lugs. I also have a GM 10 bolt rear end in 5x5 out of a 97 1500 that I will swap with some fabrication. Just note that if you go discs, you can use most years of the 6 lugs- but they only made 5 lugs from 71 and up. Not to mention you will also have to install a master cylinder, brake booster with a proportioning valve. Someone on here makes a nice bracket for that.
Do you have coils up front or torsion bars? |
If you have a GOOD skilled welder who can modify your front control arms, you can do the old school way, doing "dropped" control arms. This was done before the days of dropped spindles. I had a set from SoLow Suspensions from way back. You can basically do the same thing. Here are a couple pics. You can do a 2" drop this way and then do dropped springs.
http://gallery.lisaandmike.org/album...s/IMG_0005.jpg http://gallery.lisaandmike.org/album...s/IMG_0009.jpg |
Wonder if these would help?
https://www.performanceonline.com/71...e-2-half-inch/ |
Those are for a 71-87...would you still have to swap the crossmember/control arms to use them? |
In this day and age of parts, no one should ever need to swap a crossmember for any reason. |
Before someone buys those spindles, I would suggest checking to be sure that the '71-'87 lower ball joints will actually press into the '63-'66 C20 lower control arms.
Just talked to my tow truck buddy. We do a trade out deal. Says he got 4 or 5 C10's I can pick through and take whatever parts I want. I'm stoked.
When converting a '63-'66 C20 to a C10, you must change the crossmember as well. You can not simply bolt up any later model lower control arms as there are no saddles to locate them with.
Changing the entire suspension including the crossmember is not a big deal at all if the engine is out of the truck. You can easily have the suspension changed, power steering box bolted up and the later model idler arm mounted should you choose to go that route, in a weekend. |
Or do you plan to rebuild everything first? Balljoints, tie rods, idler arm, pitman arm, and a-arm bushings. |
Here is a pic of a '63-'66 C20 and C30 lower control arm. Notice the shape of the shaft and the 4 mounting holes.
Yep. The '67 and up have the typical round shafts.
