Door Skin Feedback
I know these questions get asked all the time and always get the same answer, “all repop stuff comes from the same place” But I still would really like to hear from those that have used the full door skin panels and what manufacturer sticker was on it.
I recently replaced a door skin with a Counterpart panel and it was pretty brutal. The 2 main body lines were easily 1/2” off from my cab lines so I had to make my cut between the 2 to maintain decent lines. The overall profile of the door is pretty bad too. Wondering if anyone has luck with Triplus or Goodmark skins? I’m talking the full one, not the 12” high one. Thanks!👍 |
Re: Door Skin Feedback
Repro sheetmetal is the absolute last resort!
That's all I know! Brian |
I hear you, then how about not replacing the whole skin? Either making or buying a patch panel or if one isn't available buying that repro skin and using the bottom foot of it, and tossing the rest in the garbage?
This is one thing I see often people will have a few inches of rust and get a patch panel that is a foot tall and using the whole thing instead of just replacing what is rusted. Now understand, I am talking in generalities here, I have no idea what so ever how bad your rust is and all that. I am just referring to what I often see on the net. Brian |
Post some pictures... we all like pictures.:metal: |
[QUOTE=MARTINSR;8178729]I hear you, then how about not replacing the whole skin? Either making or buying a patch panel or if one isn't available buying that repro skin and using the bottom foot of it, and tossing the rest in the garbage?
This is one thing I see often people will have a few inches of rust and get a patch panel that is a foot tall and using the whole thing instead of just replacing what is rusted. Now understand, I am talking in generalities here, I have no idea what so ever how bad your rust is and all that. I am just referring to what I often see on the net. Brian[/QUOTE I couldn’t agree more, I’m a strong believer in leaving as much original sheet metal as possible...less chance of me warping something too. Problem is this door has a little damage further up that was crudely pulled and bondo’d, the big skin will replace it. But if I can’t get any positive feedback on a companies skin, I’ll just keep searching for a better door. |
I made my own door skins. 4' Pan Brake & Slip roll.
Humbolt has some opportunity!
https://www.kijiji.ca/v-classic-cars...ationFlag=true |
I don't know what year the green one is but it's not 55.2 to 59...it's 60 or newer...did you see that one in the ad?
I drove to Vibank this morning intending to buy all the sheetmetal off this c60 cuz the guy said the doors and hood were minty. Well the corners were rotted and full of blue bondo. https://www.kijiji.ca/v-view-details...dId=1328292032 I’ll be honest, I’ve looked at a ton of trucks while out hunting around here and have yet to see one that wasn’t rusted in the door corners and fenders. And even if ya find one, how long til starts bubbling? I am more interested in replacing the skin with fresh metal and was wondering if anybody had luck with certain replacement skins. |
5 Attachment(s)
I stretched my cab 5". Was going to stitch the door on the center seam. Old skin removed you can see other previous repairs so decided going with a clean new skin was an obvious choice. |
3 Attachment(s)
Pic of before and after
Pic of inside roof of the cab stretch
Damn! That is some clean work man. Lines look really good ... I can’t imagine the work that would go into that project. Redoing a stock cab is a lot of work.
I don’t do custom sheetmetal so I’m just gonna order ipa Tri-Plus skin and hopefully it’s better than the Counterpart. I’ll post up some pics of how it lines up. |
AWESOME stuff Bomp!
Brian:metal: double :metal: :metal: |
In my experience Counterpart was bottom of the heap as far as body lines on cab corners, Tri-plus seemed like a nice step in quality. Not sure if those properties will transfer over to door skins buy it might be worth a shot at a different brand |
Bomp - that is some impressive manufacturing skills. Those door skins look really nice! Those are skills that don’t come over night.
that's some slick work there Bomp....do you have a build thread?
http://67-72chevytrucks.com/vboard/s...d.php?t=741512 |
That whole Photobucket thing TICKS ME OFF! Those evil bastards! I told them to go to hell.
Brian |
Re: 60-66 Door Skin Feedback
Thought I had deleted all the pictures of how the Counterpart skin lines up with the cab but found one. The tape shows where the body lines are.
http://i284.photobucket.com/albums/l...psmq8pf2sw.jpg I should have my TriPlus skin from Bills truck shop tmrw and interested in seeing if it fits any better. |
that is BAD......
Yup, after market parts usually need some persuasion to fit correctly.
Original needs a good kick sometimes too. |
Figured I’d follow up on this if anybody is searching for a good door skin. As expected, the TriPlus skin was equally bad as the Counterpart. The body lines were off by about 3/8” and I’m not even sure how folks use the complete skin successfully. I ended up doing the PS same as the DS, cutting between the body lines and basically tossing the top bit in the bin. Not exactly ideal when you’re paying $200CDN for a chunk of sheet metal.
Here’s a couple pics of how it turned out. Will still need some work, one side and the bottom need to be welded for gaps still. I tacked a piece of angle iron to it before cutting to minimize panel distortion, it seemed to work pretty good. http://i284.photobucket.com/albums/l...ps96ohoous.jpg http://i284.photobucket.com/albums/l...psuyh8nm1t.jpg |
That's when we would refer to aftermarket parts at the shop as "similar."
Brian |
Haha that’s a good way to put it |
Glad you stuck with it. You made it line up straight.
