stock chevy 292 with 4 barl intake
well its not all stock it has duel long tube headers with 2.25 pipe .with hei .so how would it work with it thanks
Re: stock chevy 292 with 4 barl intake
welcome to the board! I am sorry you didnt get a quicker reply, might have to do with the f@&d part of your user ID. I dont have any experience with this, but I dont know why it wouldnt work, just dont go overboard on the carb size.
Here is a bump to see if anyone can be of more help and again welcome! |
That would be a great combo as long as the carb isn't too big.
Does anyone have a recommendation on what kind of 4 barrel by cfm, thanks for responding
old hot rodder math is to double the cubic inch displacement of the engine, so a 600 cfm carb should do the trick, but I think it is over kill. You will get better throttle responce from a smaller 500 or 550 carb unit. When I plug the engine specs of my vortec 350 into a comuter program I have it tells me that a 600 cfm carb is all I need.
http://www.4secondsflat.com/Carb_CFM_Calculator.html |
yes it is. if I used that calculation I would need a 700 series carb. That is an awesome calculator tool nice find.
so 600 to 500 should work that good thanks
we are saying 500. If you run the carb calc that redcap posted even at 100% volumetric efficency your engine is only going to swallow 422 cfm and realistically your ve is closer to 85%
I will say that the 390cfm ran great (once someone else tuned it...) on an old Ford 300-6 I used to have long ago. |
ok thanks to all that helped me
