electronic ignition conversion
I saw at one time someone had posted a link to an electronic ignition conversion other than pertronix. The company also made reproduction wiring harnesses and seemed good quality. Does anybody know what i'm referring to?
Re: electronic ignition conversion
This one? - https://www.lectriclimited.com/conve...modifications/
Go down about an 8th of a page. Harness - https://www.lectriclimited.com/wirin...es-lead-wires/ |
Thanks Rocknrod . Actually found the one i was looking for. M&H electrical fabrications but they look to be about the same in quality. Has anyone had any experience with either of these companies?
I have purchase electrical parts from lectric limited. And I have read dozens of posts where member liked M&H product quality. Never read anything on their distributor setup though.
A conversion to HEI is about as simple as disconnecting the wire from the solenoid, dropping the HEI, and running a 12AWG switched wire.
Might want to search the internet on HEI conversion. |
But you gotta have a distributor to convert to. I don't want to use a GM distributor as I'd like to keep the stock look. That's why I'm looking at conversions.
