73 international harvester with c10 suspension
What up every one im new here but i been building my harvester for 2 years and is my daily driver i got c10 suspension in front i subframed it cutting and putting c10 crossmember i also cut lca shortened 3/4 and raised 1 1/2 worked our perfect on rear trailing arms ran on side of frame with upper link bars cnotch it lays on frame i cant get pics to post when i press choose file it does nothing
Re: 73 international harvester with c10 suspension
Try signing up for http://photobucket.com/ its free,Upload your pictures there and anything you want to post on any forum just copy and paste the img link.
we need to see these pics!
I have pics in my gallery i cant get it to upload on my post
I saw this in your profile. I assume this is the truck.
http://67-72chevytrucks.com/vboard/c...ic150671_4.gif |
Yes that my truck i been tryn all day to put pics up but only can put pics in my gallery for some reason i push choose file here and it does nothing when i select choose file
By using off-site hosting, you can put WAY more images into one post. It also helps our servers run faster by only needing to transmit a few characters as a link, instead of the full size of the image file. If you want to upload just a few pictures, by all means use the gallery....but if you want to upload a ton, or use them on multiple forums/places, its much easier to host them somewhere like photobucket and just paste the links here. |
K thanks im pretty much got most of pics in gallery already
What you can do is go to your gallery, click on the pic to open it, then Right Click and choose Copy Image Location. Then you can come back to this post and use the IMG tags. Example is [IMG]url location you copied[/IMG] Here is how it works with one of your pics.
http://67-72chevytrucks.com/gallery/...3/IMAG1947.jpg |
