Lifted 4x4 Brake Hoses
What brake hoses are you guys using for lifted trucks? Got a 70 with a 73 disk front Dana and about a 4 inch lift.
Thanks, Smitty |
Re: Lifted 4x4 Brake Hoses
I used Offroad design. I have a Dana 60 up front not a 44. But they have lots of line configurations. You can call them if your not sure what to order.
DOT approved......I hope
Point taken about measuring the lines with the axle dropped. I have been looking at all these 4X4 sites and mostly what I am seeing is about a 23 inch line for the lift on the truck that is being sold. Smitty |
ORD for sure. They offer different lengths for lifted applications and different needs.
I used ORD too, front and rear. Swapped in dana 60 and 14 bolt.
ORD! Dot Approved, says so in the hose itself.
Skyjacker ss braided D.O.T. Approved
Quality factory replacement mid-late '70s C/20 brake hoses are what I use. I tell them '78. NAPA PNs are rear - 36759 and front - 36765. I just peel the unneeded clip-on tabs off that aren't needed.
I have bought the expensive braided ss hose kit for a '72 K/20 from one of the companies mentioned above and the rear hose was wrong, wrong gender on the axle end and a size too big. I had to pay even more to have Inline tube to make one that worked as well as the correct t-block. Factory spec brake hoses do the job just fine. If you just need longer hoses and don't care about adding hoses (you don't really see) for a look, the C/20 hoses do the trick. I like that they do the trick while looking stock |
