4l60E trans swap question
is there an advantage/disadvantage to using a 4l60E over a 700R4? would it be a direct swap? :chevy:
Re: 4l60E trans swap question
Are you running F/I? You need the electronic controls to make the 4l60e to work. If you are running a carb just use a 700r4
i'm running an edelbrock 1405 carb on a 400 sb.
My transmission is whining like crazy and i'm afraid it is on its way out. I am trying to figure out all of my options. anyone know what the average cost is for a shop to replace the pump in a 700r4 is? |
Have it done NOW....Dont wait for it to break. The converter & front pump can make whining noises. |
Ok, will a turbo 350 bolt right in till the 700 gets done?
It looks like it is all the same |
If your truck is a 4X4 it won't just "bolt in", not with out a lot of other changes. If your truck is a 2wd it would fit, but you would have to move the crossmember foreward, and you might have to change the driveline, depending on which 350 you have.
its a 67 2wd with a 400SB. i can move the crossmember easy enough. i just need the right tail length then?
i went to pick up a 350 trans listed on craigslist last night and it turned out to be a 700r4. it came out of an 89 chevy and is a gm rebuild. it was in a 2wd 350 truck. wish me luck.
