NOS turn signal switch plus adapter & NOS flasher knob
$50.00 shipped lower 48 plus pp fees Just as title says $85.00 shipped lower 48 please add the 4% pp fees thanks
Re: NOS turn signal switch plus adapter & NOS flasher knob
Bump
$70.00 shipped lower 48 plus pp fees
$60.00 shipped plus pp
Hey Jeff! Is this for tilt or non-tilt? If it's for tilt I'll take it!
Thanks, Randy |
Hey Randy it's for a non tilt column thanks
Bump
Here is the deal on this turn signal switch, its really a replacement switch for non tilt applications but it will fit tilt also.
The difference is this For non tilt as far as originality it should have a fixed red flasher tang/push pull thing For tilt applications it is only missing the light bulb holder and wire which can be removed from your old turn signal switch and installed on the back of this switch. This switch also will accept the factory "horn" shaped black flasher knob that is correct for tilt columns. Hope it helps your sale. |
I will take the switch let me have the total and your paypal. Thanks Bob Would you happen to have a lower bearing and plastic bushing for the bottom of a tilt column?
