New truck!!! Build Thread
hey everyone..
This is my first truck, im 19, familiar with cars and what not just haven't gotten around to ever getting a truck. i had a 98 Cherokee 2 door 5 speed red that i lifted 4.5'' and put 34's on, that was sweet till i wrecked it, but anyway im getting this truck here http://i1310.photobucket.com/albums/...psd6e660ae.jpg its a 1990 Scottsdale with a 4 speed w/overdrive. got the Chevy 350 in it. about 70k on it frame is in really nice shape and no real bad body damage minus the D fender im buyin it off a buddy of mine with these rims http://i1310.photobucket.com/albums/...ps16b19d25.jpg they have never had anything mounted on them yet my list of things i gotta do:
Re: New truck!!! Build Thread
Not bad, what is it, it kinda looks like a 2500 or 3500 with the clearance lights and appears? to have 8 lug wheels? And 4X4 too?
Why are you taking the bed off? Search here for info on the tilt column, might only need the 3 bolts tightened. Grey will look good on it. How much fuel line repair does it need? Depending on whewe it is, it can be easy or a real pain. Fender and grille shouldn't be much problem. What transmission is in it? 5 speed manual? |
haha ok ya its a 2500, with 8 lugs, 4x4
taking the bed off to rubberize the bottom of the bed and the frame, make it easier to do cab corners and fuel lines and im gonna have to replace all lines the fender and grille will e easy just bolt on stuff and ya its a 4 speed w/ overdrive manual |
i cant find anything on the tilt problem anywhere.... without touching any levers or anything i can tilt the steering wheel from the like 7 o'clock position to the 3 o'clock position..... the PO took it apart to replace the key/ignition thing and im guessin when he did that he missed a part, any ideas anyone?
Here's a couple videos etc that might help: http://www.steeringcolumnservices.co...structions.php http://www.chevyasylum.com/column/tiltcol.html There's more out there, some better than others, read anough of them till you understand what you gotta do, take your time, and good luck! |
ok thanks and no its def the tilt feature on it...its not a steering problem actually im thinkin that first video should fix my problem!!
Nice looking truck. Just out of curiosity tho, how come your removing the grill, it looks to bre in nice shape? Anyway, looking forward to see how the project goes.
thanks! just picked it up today! and first off its purple and i wanna do like a chrome one with the black bowtie.
starting with fuel lines and probably picking up the fender sunday night. anyone have any ideas on some quality fuel lines to get |
I wanna replace all lines all the way back. It all needs to get replaced
Posted via Mobile Device |
Well little update, I've got mOn and tues off of school thanks to good ol sandy and in the mornin I'll be takin the bed off and getting everything undercoated and everything Ill post picktars when done
thanks tennessee! i was under it today and found that the rear cab supports on the frame (where the cab mounts are mounted to) is cracked and they will need to be replaced but i cant find them anywhere, not even on LMC
Little update... Got the bed off, started cleaning the frame and found that the supports for the rear cab mounts and the front bed mounts is basically gone on the bed side. Will have to patch them up. Also planning on taking out the cross member by the spare tire and replacing it with square stock. I'll post pictures later of the nice cancer I have:chevy::chevy:
Posted via Mobile Device Posted via Mobile Device |
Didn't get pictures up yet buy spent the day yesterday needle scaling the frame and cleaning that up.... Still got some to go. patched the two bed mounts and got that all squared away. Went and got a thing of por15 to help protect this thing too. Things are going smoothly.
What's left to do: Clean up bed rails and undercoat them Fuel lines from throttle body back Finish wire brushing the frame and undercoat that Fix steering wheel Get new sending unit and filler neck Fix driver door from sagging Body work and paint!!! Posted via Mobile Device |
well bed is off and the gas lines are getting replaced from throttle body back to the sending unit as with the sending unit and filler neck.... but here are the pictures. the patches arent the best but they will work.
http://i1310.photobucket.com/albums/...ps318958c1.jpg http://i1310.photobucket.com/albums/...psb14c0a80.jpg http://i1310.photobucket.com/albums/...ps19feb0fd.jpg http://i1310.photobucket.com/albums/...ps53c4c877.jpg http://i1310.photobucket.com/albums/...psa96bb904.jpg http://i1310.photobucket.com/albums/...ps277553ab.jpg |
You got yer work cut out for ya!
Those patches you welded in , make sure you grind all the old rust away and have nice shiny metal to weld on. Also your welds look a bit cold. Just constructive criticisms |
hahah no i hear ya, im not a great welder, thats for sure i barely weld, used a little hobart to do that. thanks for the imput though
you may want get your front end checked, judging by the tires on back it looks like your alignment may be off, if those tires were ever on the front of the truck.
hahahaha no there is one brand new tire on there and one bald one...thats why it looks like that.... the PO was kind a do do
mmkay, I only suggest because I had a tie rod end break on me going down the road, never been so scared in my life.
haha ya i can only imagine. that would not be a fun thing. but thanks for posting
Got the new fender on, started painting the frame, two more coats to go and the fuel lines are On the way, wait till you see these suckers
Any noise in the front end, any amount of wandering left to right, binding or bouncing and it deserves IMMEDIATE care. Even if you think its alright take a look anyways. Its well worth a few minutes with a jack to check it all out. Posted via Mobile Device |
Haha ya no I will. I'm completely going over this truck. Front to back. Top to bottom. Nothing will be left out
