Question for qjet gurus
4 Attachment(s)
What I’ve found so far is that this carb is a 69 or so, and should have a divorced choke. It’s currently on a 66 k20 with a manual choke cable but not connected. Is there a way to either a)convert it to fully electric choke, or b)somehow mount a divorced choke coil onto the 74ish egr cast manifold? It looks like a bracket has been added or change to attempt to use the manual choke cable but the angle is all wrong and I just can’t get it to work.
Re: Question for qjet gurus
You’ve got a divorced choke carb on a hot air choke manifold.
Manual choke is hard to set up as the link arm needs to move vertically. You can get an electric choke conversion but it might be tough to install it with the hot air choke cover(the square plate with the tubes in it) in the way. With a thicker base gasket which raises the carb 1/4 inch you might get one to work. https://quadrajetparts.com/electroni...bu-p-2638.html |
Keep the carb and get a eddy performer intake. Then you can set up your choke with the needed choke stove and linkage.
If you decide to go eddy carb too just remember you might need a fuel regulator and a heat plate and possibly throttle cable or rod brackets all which can add another 100 bucks over the new carb price. |
If you decide you want a qjet with automatic choke check local salvage yards. In my area they can be had for less than $50. You can also look on Ebay for some good bargains. I got one on ebay for $50 some years back and it was in excellent shape.
Like this. https://www.edelbrock.com/replacemen...hevy-8901.html You might need to use an Edelbrock divorced choke like this. I’m not sure if stock ones bolt on. https://www.edelbrock.com/quadrajet-...olds-1931.html The total price is starting to add up! |
This is the manifold and mount I need, but no coil or linkage. Can you tell if this carb was setup for manual choke, or were they just not using one?
https://columbiamo.craigslist.org/pt...668691145.html |
I was going to post a pic of mine then I remembered I don't remember how to post pics lol. I bought a manual choke kit from Carquest. It was easy but the choke works backwards. You have to push it in to close it and pull it out to open it.
https://s19.postimg.cc/yq8i591tb/IMG_3871.jpg I'll try again https://s19.postimg.cc/6q4ekyycz/IMG_3871.jpg |
I was too cheap to pay $75 for the Edelbrock divorded choke kit so I went manual.
I think I've found some of what I need here. Item #2
http://67-72chevytrucks.com/vboard/s...light=divorced |
No, they just don’t have the coil and cover and rod there.
Just recalled (foggy Memory) that a buddy had set up his with a manual choke. Worked quite well IIRC. He made a mount bracket to attach a small bellcrank to, that would move the carb linkage vertically as he pulled/pushed the choke cable horizontally. I think he got the bellcrank off a 10 speed bike. Used for shifting or braking. I’ve used bellcranks in carb linkage before. One like this. https://ultimate-hobby.com/products/...system-micro-1 Just one of many. With a little mcgyverin’ You could save some mulla! |
