Will these axles work in my 65 c-10?
hey guys I was searching and found these axles and they convert it to 5 lug too. http://www.summitracing.com/parts/SAG-PA5855/ I want to go to carlisle next week and I need someone that ships rather quickly. Has anyone used these before?
Re: Will these axles work in my 65 c-10?
I would like to know also. But mine is a 64
I just ordered them so i will let you know about wednesday next week
Application chart says yes .
If your differential is an original '64 12 bolt then these axles won't work without switching the spider gears to 30 spline gears. The '63 & '64 12 bolts had 17 spline axles and spider gears.
Mine is a 64 so I need spiders
That would be correct.....unless someone has already changed them or the complete differential within the last 45 years.
Well I have a 72 rear out back I cant sell so I guess I'll pirate some stuff off it.
What about just swapping the complete '72 differential, or is the increased width not going to work for you?
I need the narrow rear and my 72 rear needs gone through and has an anemic 3.78 rear and open where I have 3.73 lsd factory.
If your '64 has the factory limited slip for the 17 spline axles, then you might have to change the whole carrier. I'm not positive but I don't think the 30 spline side gears will work in place of the 17 spline gears.
I would suggest verifying exactly what is in your '64 12 bolt to start with, and then go from there. Quote:
