GM L31 crate engine discontinued?
In another thread someone was told by a Dealer that the L31 crate motor was no longer in production. Just wanted to see if anyone could verify or prove this wrong.
I am planning a swap into my Suburban very soon. I was waiting till I am ready to start the work to keep from it sitting around with the warranty running out sitting on floor. If it is true I guess I will go ahead and order one. But I have my doubts. |
Re: GM L31 crate engine discontinued?
Summit Racing has them with free shipping...
https://www.summitracing.com/parts/nal-12530283 But I haven't heard squat of GM discontinuing them. Gary |
i know gm dropped a tbi repacment engine and subbed in a diffrent part # a bit ago . but i also have not heard the L31 being dropped .
now i did just hear the 6.0ls engine is going bye bye for a newer bigger cid replacement . |
That is unfortunate if it is no longer in production. That would mean once the supply is sold, it will no longer be available. And the price may go up. I just checked on www.gmperformancemotor.com and it is still listed.
Summit still has them from gm, one has 2 bolt main and the other is 4 bolt main.
https://www.summitracing.com/parts/nal-12681431/ https://www.summitracing.com/parts/nal-12681432/ The one that is discontinued is the factory replacement for 8600 gvw or heavier. The 4 bolt main motor will swap right in without issue (so will the 2 bolt). I believe the only difference is different valve seats on the 8600+ gvw engine. |
They seem to have changed the part number, wonder why?
Yes it seems as though the HT 383 E is advertised now by GM as the 96-99 truck replacement crate engine
I'm not sure what the worry is, there are only about a million cores to rebuild out there.
