Collapsible Steering Column
After reading through the post and FB feed on the girl looking for her dad's car, I had a few questions about the collapsible steering columns. That post really got to me for some reason.
I have read about collapsible columns here for a few years now but never really had any idea that they were a safety feature. (take it easy on me, Im a little slow). Ive known for some time that the column in the '63 isn't stock. Ive always guessed that it was out of a 68 or later truck as it has the little red emergency flasher button on the side. My question is this; the shaft doesn't seem to be collapsible but it does have an outer sleeve that has an inner shaft that attaches to the rag joint. Is there something that I need to do to make it collapsible? Drilling a weld? Is it supposed to collapse easily or does it need an impact to collapse? Any help on this is appreciated. I may be ready to get a good set of retractable, shoulder belts in it too. The lap belts, while technically legal here do about as much as the half lid helmet that I used to wear while riding the Harley. Think my threshold for risk (and exposure of my family to it) is lowering as I get older. |
Re: Collapsible Steering Column
sub'd
IIRC there is a sheer pin that breaks and allows the column to colapse after "X" number of pounds of pressure.
I had an uncle killed in the late 1970's his 66 was hit head on by a little Fiat.The steering column pushed the steering wheel in his chest. I think in today's day and age of distracted driving LED lights are a good upgrade
New after market collumns are collapsable. And if you can make one fit, 73-94 gm collumns are too. If I were to retrofit one, I would try to get a pre 1985 collumn, so you dont end up with two wiper and bright switches.
Federal law mandated collapsible steering columns starting in 1968.
On our trucks it's the intermediate shaft that's collapsible.
69-72 trucks have collapseable intermediate shafts.
Just out of curiosity has anyone here put a 73+ collumn in a 60-66 or 67-72, and make the original steering wheel work on the newer collumn?
I would put a 69-72 column in your truck, they look alot better than the 73 and newer ones, I have some of these 73 ,74 trucks...the column doesn't mount as cleanly to the dash...columns dont look that good ..
On the seat belts, I put aftermarket three points in my '67 Panel Truck and they work really good. LockDoc |
2 Attachment(s)
This is how mine fits in the '63. Im fairly sure its from the 68 - 72 era. Any confirmation of this is welcome.
FWIW, I think it fits the mounts pretty well and looks like it belongs there. |
Man I gotta do something about those inner fenders!
4 Attachment(s)
I did my swap for several reasons, most because the stock column was really messed up and my custom steering wheel did not fit the turn signal canceling cam right. I picked up a floor shift column and intermediate shaft from a 70 C10. Solved my problem and also got rid of the 1 piece shaft. It was pretty much a bolt in. I had to redo the wires for the turn-signal switch, but not real hard.
AS far as I know, you probably could keep the original housing and just swap the shafts between the 2. I liked the later column for mine. |
Thanks Dale! But plastic? Never would have figured that. Makes perfect sense though. Wouldn't want my sternum having to shear a steel pin. |
