Lower hose vs. alternator
Is it possible to find a lower hose that will fit radiator to water pump with the alternator in the mid-mount position?
Posted via Mobile Device |
Re: Lower hose vs. alternator
I'd put the alternator where it belongs so it doesn't get splashed with water and crud in the winter. But that's just me
Do you happen to have a lower rad. hose part # for me? |
Easter to see :)
Considering the alternator on all V-8 67-72 trucks was on the drivers side with a short water pump, it looks like you'll have to come up with a different solution than a stock hose.
You could bend a wire coat hangar, or other hunk of sturdy wire, in the shape and length you'll need and head to the parts store to see what you can compare it to for fitment. Gary |
3 Attachment(s)
Gates 21849....
Is that some sort of extension coming off the water pump? |
Here is a link to a youtube video on wiring the fans. I used a BMW temperature sensor. https://www.youtube.com/watch?v=nAKn...ndex=40&t=740s Here is a link to the BMW switch. I used a 81/88 Deg C switch and wiring harness that I found at a local Pick'n Pull https://www.youtube.com/watch?v=88jkW4mC8oY |
I looked and nobody seemed to have the hose in-stock locally so I immediately ordered that sucker on-line, very interested to get that crossed off the list, Thank-you again. It should work, your radiator looks very similar to mine.
I also used a dual fan controller but went with a dakota digital, probably cost me more than yours did. It did, however, come with excellent wiring diagrams and the two relays needed. Said I could use the temp sender if it was from Classic Instruments, which mine is. So we'll see. Getting ever closer to start-up....... |
