carb leak rochester 4bbl
just had this carb rebuilt and its leaking where its circled in yellow. what can i use to stop this? epoxy?
Re: carb leak rochester 4bbl
Those plugs eventually leak on Rochesters, just clean well and use some JB Weld epoxy. Let it fully dry before letting fuel get on it.
thanx, i ran it outta gas and hit it with air to dry. dumb question, whats this for?
For a cleaner look use some of this. It’s clear.
It’ll seal a 1/4 inch hole in a gas tank, so it’ll seal your leak. https://www.homedepot.ca/en/home/p.s...000708738.html You did know not to use teflon tape on flare fittings, didn’t you? I see some on your inlet fitting. |
Your carb has several. Passages so they can machine inside the carb. |
thank you
