350 crate engine questions
My build is progressing somewhat and I am looking ahead to my power plant.
I have a 350 crate motor with 4 bolt mains - not sure of year produced - that I planned to use when I get to that point. The previous owner of the engine drove the truck it came out of into his shop and around some before pulling it in favor of an LS swap. I need to state up front that all I am interested in is a dependable, serviceable engine. No street monster with loping cam. I plan an Edlebrock aluminum intake and headers as only changes from stock at this point. I am capable and confident of my skills at rebuilding this engine, but wonder if I would be better served as well as coming out ahead dollar wise purchasing another crate engine new and selling the one I have? It would seem to save time over the term of my build and not knowing for sure what lurks in the internals of the current engine and worrying about cost of machine work to get it in stable condition I'm thinking I might be money ahead?? Comments - advise - criticisms?? Thanks! Jay |
Re: 350 crate engine questions
If you have no idea of how many miles it has on it, run a compression and leak-down test. You could also bore scope the cylinders to see what their condition is. And if you want a quick and cheap check of the bottom end, use Plastigauge.
If you don't want a street monster, why go with headers? For that matter, with a stock crate motor an aluminum intake might not gain you enough to make it worthwhile. |
I will comment.
Put yourself in their shoes. I am speaking of the person that would purchase this engine. 1st question; Can I hear this engine run? 2nd question ; Can I drive the vehicle till the engine is (up) to operating Temperature? With that being said: What state is the engine in now? Why Do you think it needs to be rebuilt? Now: I would try to use this engine to motivate (move the truck around) my project truck. Then sell it to a person that can see it run. just my opinion:smoke: . |
IMO unless an engine can be started and run to try and make a sale, it is only considered a buildable core. If you get the engine setup and runable, you just might decide to keep it.
I vote for this option;) . |
Since your linitiall description said.."into his shop and around some" it makes it sound like the motor is still rather fresh. I was actually expecting more of a "starting it up after long term storage thread" here and was surprised when you said you were gonna rebuild it. I'd at least check the slop on the timing chain by turning the balancer back and forth while watching the distributor rotor for movement. If there's not much play, it clearly would be a good sign for following thru with what some of the other guys are saying.
But that is just my 2 cents..... |
