Best way to put motor back in ???? SURFACE RUST ON FLYWHEEL---
Have two types of attachments. Carb plate and equalizer type. Are aluminum manifold bolt holes strong enough to support the weight of a SBC ? Or should I just use the equalizer attachment. I am leaving the clam shell mounts loose on the frame as I have read I should do. I. tried finding the thread I read about this but failed. Any tricks etc. you guys know ?
Had flywheel resurfaced but health problems set me back almost two years so there is surface rust even thought I had it wrapped in bubble wrap. Best way to clean it off ?? Thanks in advance for your generous help/comments. |
Re: Best way to put motor back in ???? SURFACE RUST ON FLYWHEEL---
I prefer the balance/equalizer beam to install engines...ive seen many of them lifted with carb bolts...but I wont ...
fine sand paper or scotchbrite might clean the flywheel https://www.hotrodders.com/forum/rem...el-415850.html |
Four 5/16" bolts are more than enough to support a SBC assuming the threads are in good shape.
Back when Gen 2 LT1's were popular, I had a lift plate that used the 4 6mm bolts that held the Injector Rails down......Never had a failure! |
Since I work alone most of the time, I prefer the equalizer. It lets me get things lined up the way I want them more easily. I just dropped in an engine yesterday and the equalizer let me line it up with the bell housing without having to fight the engine's weight with one hand while installing bolts with the other.
I agree with fine sandpaper or Scotchbrite, followed by a good cleaning. |
and this is what happens when things don't hold...
when I bought this engine , it was in a running truck..they pulled the engine for me when I went to pick it up they had it swinging off a huge forklift with nothing but a seatbelt looped over the fork and tied to the exhaust manifolds...told me they pulled 1000s and never lost one when I asked...I didn't even make it from the truck into the shop when the belt broke.... that equalizer bar is worth the money for installing...especially with a manual trans |
I just use the carb plate with 5/16 bolts, simply because I do not own an equalizer! I've installed many SBC/trans combinations with success by myself, using a floorjack under the tranny to level things out.
I figure the flywheel is just like brake rotors that rust up in a week if you don't drive the vehicle. It should smooth right off. It would probably rust while sitting inside the bell housing anyway.
I also don't trust aluminum manifold threads to hold an engine no matter what the engineers say. |
I dont trust it either but I have done it before. Mostly when moving engines around before install or after removal.
I use the bracket/hooks that come from the factory. A leveler is good to have but I never used one. I start one bolt in the trans mount and then start one motor mount bolt. Then remove the bolt in the trans mount and move the tailshaft while using a short punch to line up the other motor mount.
My cousin who worked at a Chevy dealership when these trucks were new said they just drilled out the hole in the mount and used a washer. |
I can see what would happen to my primo next engine build. Aluminum Intake, ok the Bar thing has won. |
I've installed Iron headed Big Blocks with lift plates & yes they had aluminum intakes.....I really don't see the issue? Now that I think about it....I've installed several TBI big blocks using a lift plate & they only use 3 bolts instead of 4. To each his own....If you don't feel comfortable, Do whatever you feel safe with!!! |
TY all for the input much appreciated.
