67-72 Oct 04 Voting Poll
5 Attachment(s)
mike c
General Manufacturer: GMC Model: Jimmy Year:1972 How long have you owned this truck?: Me since 1987, my Dad bought it in 1977. History behind the truck: Dad traded in the '64 Rambler wagon (what a piece!) for it. First cool vehicle we had. I learned to drive in it when I was 11. In the mud. In 4 wheel drive. Through a creek and over a mountain. Ran over a stick that flew up and dented the hood. Too cool! Chassis Suspension type: Rancho 4" front, National Spring 4" HD Rears Front Brakes:New 1/2 ton GM Modifications:4 Rear Brakes: New GM. Steering:AGR steering, 4" ProComp arm, new drag link Front and rear tire/wheel type:Centerline 15x10 ProTruck Wheels Front differential type / Gears:Dana 4.09 Rear differential type / Gears:Richmond 4.11 thick gear on factory Eaton 3 series posi. Body Color Scheme:White onw white Bodyman: Me! Modifications: trimmed rear wheel wells Paint Type:DuPont Acrylic laquer Painter: Me! Interior Color:Black Material:Cloth Upholsterer:Proverbial little old lady in Dad's hometowon Wiring:Original GM Modifications:Homemade door panels and side panels, Smittybuilt cage, Steering wheel/Column:stock column, '74 Camaro wheel in the pics, currently runs a 92 GMC leather wrap. Stereo/Speakers/Amps:Alpine pullout-1 of many I have! Kicker amps and speakers. Thanks Tracy F. and Kicker, Inc. Air Conditioning:factory and yes, it works! Instrument Gauges:GM fuel and speedo, Sun Super Tach I (yes, one) and Autometer oil, water, vac, volts. Engine Cubic Inch:331 Manufacturer:GM Camshaft:Crane 266/266 .440/.440 Cylinder heads:one 186 and one 041...don't ask. Valve Covers:1970 Z/28 Intake Manifold:Weiand 8004 Ignition System:MSD ready-to-run Exhaust type:2 1/2" 'vette manifolds with aluminzed pipe and Walker 2 1/2" Hemi Turbo mufflers. Transmission Automatic / Standard:SM465/NP205 Torque Converter: Modifications:350k miles plus! Shifter type:stock chrome, replacement OEM ball Drive Shaft:stock front, custom CV joint rear. |
5 Attachment(s)
and the rest
5 Attachment(s)
CPNE
General Manufacturer: GMC Year: 1972 Chassis ¾ ton 4x4 Suspension type: Factory HD Springs, front and rear Front differential type / Gears: Dana 44 4:10 Rear differential type / Gears: Dana 60 4:10 Engine Cubic Inch: 350 Manufacturer: GM Transmission Standard: 4 speed This month’s theme is “rain, mud, snow and all that fun sloppy stuff” befitting what my truck is all about. It’s not a high-power, heavily modified off-road mud toy by any stretch of the imagination. It’s actually quite utilitarian, VERY rough around the edges, and definitely not pampered. It is after all what almost every one of our trucks was when new – a means to an end – a mere tool used to get some task done. To think that it has survived 32 years of hard labor intact and still performing its intended duty speaks volumes for these year trucks. After all, this truck has always been in New England where the years are not kind to vehicles of any kind, especially 4x4’s. For these reasons, I believe it’s deserving of TOTM, despite its obvious lack of “sex-appeal”. A little history on my truck. When purchased new, it was intended to be a plow truck. It was ordered with HD springs (front and rear), HD clutch, cab roof clearance lights, medium blue paint, and not much more, not even power steering. It’s been outfitted with the same 8 foot Fisher plow since it left the dealership. There is evidence it had a sanding/salting unit installed in the bed at one time as well. Not much has been done to this old girl over the years. It still has the original split rims on the rear and everything is intact and functioning. I’d venture to guess that it’s gone nearly as many miles in reverse as it has forward, most of it in 4lo. Someone did give it a Dubie-style suede black paint job (sans flames), and I installed the blue bench seat. Future plans for it are to install power steering as turning the wheel with the big heavy plow and no PS is difficult to say the least. I’ve also refurbished another cab and have a rust-free bed awaiting the day I can tear it down. The plan is to put a 68 GMC nose on it and paint it 67/68 medium green. I’ve got the correct ¾ ton 4x4 dog dish hubcaps for it too, and if things go well I’ll have a 292 I6 to transplant. Do I expect to win TOTM? No, as the others have much greater visual appeal to the majority of board members and deservedly so. I suspect however, there many be a small handful of members who share my function-over-form viewpoint. Thanks for looking. |
3 Attachment(s)
and the rest
4 Attachment(s)
Pont
General Manufacturer: Chevrolet Year: 1967 How long have you owned this truck?: 4 yrs, 2 mo History behind the truck: The truck was manufactured in the Fresno, CA plant. It's home was in Stockton, CA until 1980 when the previous owner brought it here to Southern Oregon. I bought it from the previous owner in August of 2000. Chassis Suspension type: Skyjacker SoftRide Suspension Front Brakes: Disc Modifications: None Rear Brakes: Drum Steering: Crossover Steering / Power Steering Front and rear tire/wheel type: 35x14.5x15 Super Swamper SSR Radials / 15x14 Weld Typhoons Front differential type / Gears: Dana 44 / 4.10 gears Rear differential type / Gears: GM 12 Bolt / 4.10 gears Body Color Scheme:Two-Tone Metalic Blue & Silver Bodyman Modifications: Stock Paint Type: Unknown Painter: Unknown Interior Color: Blue, Black & Grey Material:Cloth Seat Cover / Vinyl Door Panels Upholsterer: None Wiring: Stock Modifications: One Piece Power Windows Steering wheel/Column: Grant Aluminum / Stock Column Stereo/Speakers/Amps: Sony CD / Infinity Kappa / None Air Conditioning: No A/C Instrument Gauges: Stock Engine Cubic Inch: 396 Manufacturer: Chevrolet Camshaft: Stock Cylinder heads: Stock Valve Covers: Chrome Edelbrock Intake Manifold: Holley Aluminum Ignition System: Mallory Unilite Exhaust type: Hooker Comp Headers, 2 1/2" pipes, Flowmaster Delta 50 Series Transmission Automatic / Standard: 4spd SM465 / NP205 Torque Converter: N/A Modifications: None Shifter type: Stock Drive Shaft: Stock |
2wdblazer
General Manufacturer: Chevy Year: 1972 How long have you owned this truck?: 1 1/2 years History behind the truck: Nearly rust free truck I got from E-Bay for a steal. And it was local. Chassis Suspension type: 1/2 ton springs, 6 inch suspention lift (3 inch body as well) Front Brakes: Stock disk Modifications: n/a Rear Brakes: Large 3/4 ton Drum Steering: Power Front and rear tire/wheel type: 38x15.50 Parnelli Jones on 15x10 Chrome Mods. Front differential type / Gears: 3:73 soon to be 4:56 (Awaiting 8 lug Dana 44 transplant) Rear differential type / Gears: 3:73 soon to be 4:56 (Rear has been upgraded to a 3/4 ton 14 bolt FF) Body Color Scheme: Viper Race Yellow Bodyman Modifications: Paint Type: Base coat/Clear coat Painter: Interior Color: Viper race yellow metal Material: Cloth Black Late 80's Volvo seats. Upholsterer: Wiring: Modifications: Steering wheel/Column: Grant GT Wheel Stereo/Speakers/Amps: 2 5x7 Blaupankt in Dash, 2 6x9 Sony Explodes in doors, 2 6x9 Sony Explodes in back. Air Conditioning:Set up but currently not working. Instrument Gauges: Stock Engine Cubic Inch:350 Manufacturer:Chevy Camshaft:Mild cam of unknown decent. Cylinder heads:Stock Valve Covers: Chrome Intake Manifold:Edelbrock Performer Ignition System: Exhaust type: Headers, dual exhaust to Dynomax Ultraflow mufflers. Transmission Automatic / Standard: Auto 350TH Torque Converter:Stock Modifications:Shift Kit Shifter type: Stock Drive Shaft: This truck is just an attention getter. Its one thing to be big but to be yellow as well, it honestly drops jaws. http://207.44.196.117/vboard/attachm...d=100358&stc=1 http://207.44.196.117/vboard/attachm...d=100359&stc=1 http://207.44.196.117/vboard/attachm...d=100360&stc=1 http://207.44.196.117/vboard/attachm...d=100361&stc=1 |
k5krazy
sorry I did not receive any pics or specs |
breeh waiting on info
3 Attachment(s)
500hp/sb
General Manufacturer:Chevy Year:1970 How long have you owned this truck?: 1 year History behind the truck: Chassis Suspension type:leaf spring Front Brakes:Drum Rear Brakes:drum Front and rear tire/wheel type:35 12.5 R15 BFG AT's Front differential type / Gears:Dana44 3:73 Rear differential type / Gears:GM 12 bolt 3:73 Body Color Scheme:white....kind of flat white Modifications: Paint Type: Painter: Interior Color: Material: Upholsterer: Wiring: Modifications: Steering wheel/Column: Grant gt mahogany Stereo/Speakers/Amps: Alpine CD player 2 6x9's Air Conditioning:none Instrument Gauges: oil pressure, temp and a Kragen tach Engine Cubic Inch:350 Manufacturer:Chevy Camshaft:Comp Cams XE268 Cylinder heads:World Industries SportsmanII Pistons: TRW 10:1 Valve Covers:Chrome Intake Manifold:Edelbrock C-26 Dual-Quad Ignition System:HEI Exhaust type: Thorley tri-y's with dual 3" Magnaflows Transmission Automatic / Standard: Standard SM465 Torque Converter: Modifications: Shifter type: Drive Shaft: Transfer case: NP205 |
MAC67
General Manufacturer: CHEVROLET Year: 1972 How long have you owned this truck?: History behind the truck: 2 YEARS Chassis Suspension type: LEAFSPRUNG BARS Front Brakes: STOCK DISCS Modifications:8"SKYJACKER LIFT L&L LADDER BARS , TRACTION BARS Rear Brakes: STOCK DRUMS Steering: STOCK WITH DROPPED DRAG LINK AND RRAISED STEERING ARM Front and rear tire/wheel type:39.5X18X15 SUPER SWAMPER BOGGERS ON 14X15 AMERICAN RACING ALUMINUM RIMS Front differential type / Gears: OPEN 4:56'S Rear differential type / Gears: 4:56 POSI UNIT Body Color Scheme: MIDNIGHT BLUE Bodyman Modifications: 68 VETTE FENDER FLARES , LOUVERED BOWTIE PIN STRIPED TAILGATE Paint Type: BASE/CLEAR Painter:BODY BY GRAVESON STRIPES BY ROY Interior Color:BLUE Material:LEATHER Upholsterer:? Wiring:SELF DONE , 50% STOCK Modifications: CD,TILT CB, AIR , 4 KC DAYLIGHTERS Steering wheel/Column: FACT TILT WITH 70'S WHITE GRANT WHEEL Stereo/Speakers/Amps: KENWOOD CIRRUS FLIP DOWN DECK , 4 PIONEER CANT REMEMBERS LOL Air Conditioning: AFTERMARKET AIR Instrument Gauges:STOCKERS PLUS AUTO METER 5 INCH MONSTER TACH WITH SHIFT LIGHT , AND AUTOMETER LIQUID FILLED OIL AND TEMP GAUGES AND AUTO METER FUEL GAUGE Engine Cubic Inch:468 BIG BLOCK Manufacturer:CHEVROLET Camshaft: CANT FIND THE CARD Cylinder heads: DECKED 60 THOUSANDTHS , BOWL HOGGED , 3 ANGLE VALVE JOB , PORT MATCHED Valve Covers: MOROSO Intake Manifold: EDELBROCK PERFORMER RPM ,PORT MATCHED Ignition System: STOCK HEI Exhaust type: 3 INCH DUAL CHAMBER FLOWMASTERS Transmission Automatic / Standard:TH 350 AUTO Torque Converter: 3000 STAHL Modifications: SHIFT KIT , EXTRA CLUTCHES Shifter type: STOCK SOON TO BE HURST QUARTER STICK THAT I HAVNT INSTALLED YET , WAITING ON LINKAGE Drive Shaft: CUSTOM LENGTHENED FROM NATIONAL DRIVETRAIN http://207.44.196.117/vboard/attachm...d=100626&stc=1 http://207.44.196.117/vboard/attachm...d=100627&stc=1 http://207.44.196.117/vboard/attachm...d=100628&stc=1 http://207.44.196.117/vboard/attachm...d=100629&stc=1 http://207.44.196.117/vboard/attachm...d=100630&stc=1 |
Question? In the fourth (last) picture of Pont the left rear tire does not seem to be inside the fender well. Has an axle let go or is this a photoshop photo?
no thats no photoshop picture , that truck looks that good by itself lol !! it may appear that way because the picture was takin in the morning or the evening with the sun to that side , and those tires if i remember right are 15 inches wide , and with that kind of lift there is nothing to cast a shadow on the tire especially with the location of the sun so it appears to not actually be under it , but trust me that is one sharp a$$ truck and its as real as it gets !!
Mac is right, it's just the way the pic was taken and how the sun exposes all of the tread without any shadow to show how far they actually stick in or out of the opening. Here's another shot (excuse the ugly mutha in the pic) that might show better, how the tires actually sit in or stick out.
On a side note, thanks tons Mac for your kind words! It means alot to me coming from someone with a rig as nice as yours! I'm honored........ |
Hey Quit Leaning ON MY TRUCK! ;) ;)
I gotta vote for pont........
THIS IS A FRICKEN OUTRAGE !!!!
ahhhh im just bull5hittin lol , yall thought that was gonna be a juicy post huh ? lmfao , anyways let me be the first in the thread to say congratulations pont , i think the most deserving won , after all those times bein nominated ya finally got one !!! congrats on a well deserved win , i think the better truck won , again man congrats and thanks to all that voted for me , maybe another time . :P |
