a frame
the bottom a frame on my truck doesn't look like it is positioned right . ok you knowhere the u joints hold it to the crossmember does the a frame fit centered are pushed back even with the frame . if i could see some pictures of a finished front end i will know where to put it . i took pic of before i started took them to walmart and they f**ked them up the compensated me but i lost the pix .
i can not understand you english? u joints are in the drive shaft. i have lots of pictures, "but you no maka since". i think i just understood your english. i was reading a just as an a, and you mean A frame. my bad. i think you might be asking about the u bolts that hold the lower contol arm on. if you mean them - there is a locating stud on the crossmember that fits into a hole on the lower control arm. here is a good photo.
with that pic you answered my question
