70 Suburban 4X4 chassis FS
A buddy of mine said he has a complet 4X4 chassis for sale $1000. It has a 350, with 4 speed trans and tilt colem and more. Mostly he is using the body. roof air gose to. I will get some pics.
4x4 truck conversion
Just a FYI......These sub frames can be used for a 4x4 truck conversion. You'll need cab & box mounts.
NO!!!!Don`t do that!Truck frames are so much more plentiful.If it were closer,I`d be on it.You should move this to the Suburban site.2wd truck frames can be used for 4wd conversion.
That would be a nice frame to put under the 67 panel that pickupman has for sale...
Chuck |
I plan on getting the pics Monday. The guy is going to make a 4 door short bed and put all lat model stuff in it. Choppet top shaved drip rails It should look real nice when done he is real pickey on his work. So all that was not going to be reused is going.
Another one bites the dust... :whine: Shame you weren't A LOT closer, I wouldn't mind havin' that chassis.... Keep us updated, we want pics!!!!
pic
