EFI Fuel Tank / EFI Wiring (TBI) Qst
Guys and Gals,
I am currently working on a 72 4X4 Blazer and am installing a complete motor, trans, transfer case (NP241) from a '91 Blazer that I am parting out. I have everything ready to install but have questions concerning the install of a electronic fuel pump for the TBI. Other than using the stock tank with an in-line aftermarket pump, can I use the '91 tank complete??? It appears that it is to long (front to rear). How have others done this??? Problems? Also concerning wiring.... I still have the '91 and all the wiring. I pulled the engine harness (Computer to fuse-box) and am working on the removal of the under-dash harness. This is where it gets complicated.... Has anybody done this as well or should I cough up the $289 for a Painless harness?????? What speedos work with the electronic outout on the 241??? Thanks for the help in advance.... My goal is to install next week and have running by August.... |
Welcome to the board. Any pics of your blazer??????
As far as answers, I see you already know your options. I'm planning to do a similar thing with my 69 K5 so I'd be interested in seeing response. However, I would guess that the Painless harness will make the install easier..... you just gotta decide how much your fustration is worth ($289?). Can you take the in-tank fuel pump out of the '91 tank and get it to work in your '72 tank? |
