-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   68 4x4 suburban suspension/disc brake questions (https://67-72chevytrucks.com/vboard/showthread.php?t=17329)
hifiguy 07-03-2002 04:27 AM
I'm currently looking at buying a 68 4x4 suburban that has a 4 inch lift and has a 79 chevy front axle installed. I think the 67-68's normally had drum brakes in the front so I assume that the reason they swapped in a 79 front axle was to gain disc brakes. Now my question is this: while looking the truck over I noticed that the left side rear shackles were bent out about an inch or two. After looking more closely I noticed a crack in one of the shackles aroung the upper bolt hole. To me it looks as if the spring perches on the 79 front axle don't line up exactly where the OEM 68 leafs sit, and because whoever did the swap didn't take the time to relocate the drivers side spring perch, they had to bend the shackles out to accommodate the new spring location that is now determined by where the spring perches reside on a stock 79 front axle. Does this seem like a correct diagnosis of the problem, or am I way off base? Can a 79 front axle be swapped into a 68 with no problems? If not what should be done? Is it a common swap? Any info would be greatly appreciated as I'm new to the 4x4 versions of the 67-72's
JIMs70GMC 07-03-2002 05:40 AM
I was under the impression that the spring perch spacing was the same on all GM front axles. But if it's cracked you got problems. Those are not the easiest things to crack, sounds like it might have landed hard. Only the rear spring perch locations changed, as well as rear shock mounting points.
Welcome to the board.
Pont 07-03-2002 10:48 AM
I'm currently running a Dana 44 disc brake front axle out of an 80 Blazer in my 67 SWB 4x4. It bolted right up. No problems. Jims70GMC is correct on the rear leafs. The centering pin on the 69 and newer is offset where the 67-68 are centered from eye to eye. Shouldn't have any problems with a 79 front axle from what I know of this.
