I need help on my 67 c10
I just bought a 67 c10 small window original truck with a six cylinder. Anyways 6000 later and a 383 stroker I need to know if there is a different clutch linkage set up cause i cant get this one to fit with the headers. Any pics would be great or info.
Re: I need help on my 67 c10
running a 3speed? Maybe you should get some shorty headers. Then it will clear.
The headers are most likely the problem. Different brands will fit differently. Like davidh says, shorty's are probably best. I have that on my list to do also. The PO just hammered the back tube until it cleared.
BTW Welcome from N Texas |
Do the headers run into the linkage tube itself,or one of the two arms(tabs)that are on it?I have relocated one before.Clean all the grease out,cut it off and reweld out of the way.
Are you trying to run the 6 cyl clutch linkage? Its differante for a 6 to a V8
Yes im running long tube headers and a 3 speed(runs like a sewing machine, but wicked at high rpms). My problem I think i need to jack the motor up on the drivers side then put the z bar in. I dont even no if the linkage hits the header yet. Also I noticed that my engine mounts are on the rear two holes while my buddies auto runs in the front two hole. Is that supposed to be different on auto vs. manuel?
front holes are 8cyl and 6cyl are rear.
when the motor's in the front 2 holes, flowtech headers will clear. what i have on my '69. got them at autozone for $85.
Thanks for info I just cut the arm off the linkage and re welded it on in right position.Works great.
