TOTM- March 2006- The Beasts
2 Attachment(s)
67c10step
1967 C10 panel Rust on every body panel. 327 V8 350 Auto trans |
Re: TOTM- March 2006- The Beasts
2 Attachment(s)
Superron21
1968 GMC 3/4 ton 4x4 283 4 speed 4.56 gears 6" lift 36" tires some rust but it just adds character.....NO power steering or Brakes - manual locking hubs - the front porch is made outta 1/2 plate (sticks out 13 inches) with an old power wagon winch, while out back is a 6" channel iron rear bumper with 6" clevises and my tow hook is from a 55 ton crane, its my "anti tailgater" deterent (sticks out 27 inches) and makes a handy counterweight (175 lbs) for when i stand on the front bumper to check the oil..... |
2 Attachment(s)
Longhorn Man
1970 C30 Longhorn Caddy 500 and a Pontiac TH350, eaton rear with 4.10 gears While not the eye sore it was a few years ago... in no less than 7 colors... |
2 Attachment(s)
stan79chevy
79 chevy half ton 4x4 rebuilt 350 bored .060 and done up a little, transmission is a th350 with TCI guts in it, the transfer case is a np205 out of a 70 blazer, the front axle is a dana 44 the rear is a 14 bolt ff 4.56 gears the axles came out of a 3/4 ton 77. the tires are 36.5x14.5x15 and it has no lift, i used a sawzall and trimmed the rust to make them fit. It is all one color rattle can black primer. Its mostly dents and rust. the only body mods ive done are put on a tailgate and grill from a 73 gmc. |
2 Attachment(s)
HeavyD
1971 C10 smoking 307, Th350, 3.07 rear |
2 Attachment(s)
POS72K10
1972 K10 3/4 axles, 350 4 speed, plenty on rust and leaks for every year shes been around! |
2 Attachment(s)
vtblazer
1971 K5 Blazer 350/th-400/203-205 doubler/D60-high pinion/14 bolt FF/5:13's/4whl disc/39.5 TSL's on 39.5's. Scares the neighbors everytime |
2 Attachment(s)
rmurray25
69 Chev K10 rebuilt 350 four bolt with 2.02" double hump heads and a healthy cam. I swapped the front diff with one out of a 70 k10 because the 69 was a close kuckle setup and dana considers it obsolete and does not make parts for it any longer. With that I swapped the rear axle to have a matched set and was pleasently surprised to find out the rear was posi. 3.73 ratio |
2 Attachment(s)
to bad i didnt know... heres mine
OK, heres a write in for you, I like your GMC the best
Sorry Andy, I like the work that you have done on yours too, but I just love those GMC's |
(mine looks like a GMC)
It was a toss up between superron and vtblazer, but superron's rare optional rear tow hook swayed my vote. lol Besides I'm partial to the 4 eyed beasts!
:cong: superron
A true beast among beasts. :lol: |
what can i say but thanks for creating a category my truck would have a chance in, and the real thanks goes to GMC for making the truck to begin with!!!
