Manual to auto help plz
68 has manual in it I want to put an auto on the flloor, what will I need to do this will it be an easy swap?
Re: Manual to auto help plz
Pretty easy swap,You'll need an Auto crossmember,trans cooler/rad,trans lines,shifter,possibly driveshaft or yoke depending on what's in it now.Trans/converter,and a free weekend.
If it has the crossmember under the bellhousing you'll have to remove it,may take some time as it's riveted in.That's prolly the hardest part of the whole deal. |
