3.73 or no 3.73,that is the question
Ok, I have prices for my gear selection
$125 for new 3.73's $275 for a new posi case $50 for a new bearing/seal kit $150 for install ____________ $600 total My question is: Should Pay the extra $125 for the gears, or should I just leave it 3.07 and just have the posi put in? |
Re: 3.73 or no 3.73,that is the question
Depends.
If you have an OD tranny, I'd use a 3.73. If you have a non OD tranny like a th350 or th400 I'd use the 3.07 unless you haul trailers all the time or something. My $0.02 |
depends what you want to do with the truck. and what kind of mileage you expect to get.
Split the difference with a 3.42.
I have a TH350 so, maybe I'll stay with the 3.07's.
I like my 3:73 posi rear:burnout:
I have 3.42 w/ t350 trans, works for me.
Depends, do you like to buzz the motor? Remember that with standard sized tires (28-30" or so), 60 mph with 3.73's and a 1:1 final gear ratio is 3000 RPM...
If you want to win drag races 3.73.
If you want something with reasonable fuel economy (for our trucks that is) stick with the 3.07 |
i've got 3.43 in my daily driver. i got 11.88 mpg wit the 305 in my sig. turns 3000 doin 70mph, about 2000 doin 45mph. the trans is 4 spd saginaw, 1.1 final gear. im lookin to get 3.73 posi rear end. chris.
