1972 Chevy Cheyenne 3/4 4x4 Project
This is my first off frame restoration.
The List: 337ci Small Block Chevy (327 Bored 60 over) 91/2:1 Compression TRW Pistons Crower Cam Edlebrock Intake Holly Street 670cfm Carb GM Performance double hump heads MSD Ignition HEI Distribitor MSD 8mm wires FlowTech Headers Rebuilt Turbo 350 with Stage 2 Shift Kit 2200 RPM Stall Torque Convertor NP205 Transfer Case Front: Dana 44 with Splicer Hubs Rear: Eaton 5002 Custom 12" Lift 39.5 IROK Swampers on M/T Wheels Before Pictures: http://img.photobucket.com/albums/v6...n/P9161027.jpg http://img.photobucket.com/albums/v6...n/P9161028.jpg http://img.photobucket.com/albums/v6...n/P9161023.jpg So far we have removed the orignal 350ci and turbo 350 and body. http://img.photobucket.com/albums/v6...s/PA050194.jpg http://img.photobucket.com/albums/v6...s/PA050171.jpg http://img.photobucket.com/albums/v6...s/PA050174.jpg I have been working a lot on body work. I have coated the frame with a 3M undercoating. I just started on primering the cab. http://img.photobucket.com/albums/v6...s/PA050187.jpg http://img.photobucket.com/albums/v6...s/PA050188.jpg I will have pictures up soon after I finish spraying the primer. For now here are the pictures of the 337. http://img.photobucket.com/albums/v6...s/P9290146.jpg http://img.photobucket.com/albums/v6...s/P9290142.jpg |
Re: 1972 Chevy Cheyenne 3/4 4x4 Project
Looked like a pretty clean truck to start with! I will be watching your build. Can't wait to see what it looks like when you get done. What color are you going to paint the body? ...Joe
looks like your off to a good start.
Can't wait to see it when it's done! ...Joe
Let me start with saying the body work SUCKS!!!! I am so tired. Things have slowed down over these last few weeks. I have finished stripping the old cab of all the things I needed and took it and the bed down to Early Classics for store credit. They have been a great help.
So here is what we have been able to get accomplished... I have cleaned and sprayed the frame with a protective coating by 3M. http://img.photobucket.com/albums/v6...s/PA050187.jpg http://img.photobucket.com/albums/v6...s/PA050188.jpg I started spraying primer on the cab, and doors. http://img.photobucket.com/albums/v6...s/PA140194.jpg http://img.photobucket.com/albums/v6...s/PA140195.jpg http://img.photobucket.com/albums/v6...s/PA140196.jpg http://img.photobucket.com/albums/v6...s/PA140209.jpg We have also installed the 337ci Small Block Chevy Engine, new Turbo 350 Transmission, NP205 Transfer Case, and 40 series Flowmaster exhaust system. http://img.photobucket.com/albums/v6...s/PA130184.jpg http://img.photobucket.com/albums/v6...s/PA130188.jpg http://img.photobucket.com/albums/v6...s/PA130187.jpg I already have another update coming as soon as I get the pictures on my computer. Heres a teaser for you ...Lets just say that I'l be driving the truck next weekend. |
you got that right body work does suck expecally on the cab.....until you see it painted then its worth the work.....and the motor looks great
Ok we are almost finished! Tomorrow the truck will go down to Automatic Transmission Center to have the new tranny to be repaired. I received a defective tranny. So i have to let them fix it. Anyway here are the most up to date photos...
http://img.photobucket.com/albums/v6...s/PA260008.jpg http://img.photobucket.com/albums/v6...s/PA260006.jpg http://img.photobucket.com/albums/v6...s/PA310014.jpg http://img.photobucket.com/albums/v6...s/PB050030.jpg http://img.photobucket.com/albums/v6...s/PB060036.jpg http://img.photobucket.com/albums/v6...s/PB060037.jpg http://img.photobucket.com/albums/v6...s/PB060046.jpg http://img.photobucket.com/albums/v6...s/PB050020.jpg http://img.photobucket.com/albums/v6...s/PB050022.jpg http://img.photobucket.com/albums/v6...s/PB050021.jpg I should be able to drive it around the block tomorrow!!! Oh and by the way the engine sounds awesome!!!! I finished primering the bed on saturday along with installing the new glovebox. Today I ordered my new wheels, tires and shocks. I should get all of that by friday. I will have pics of all the lift kit and tire/wheels by this weekend for ya'll. |
Nice work,and a lot of it!!!!!!!!
Cool project. What will you do to address the steering with 12" of lift? Who is making your springs? What gear ratio will you be using in the axles? What tire size did you finally decide on? Man, I sure have alot of questions! :lol:
Phase one is complete!!! I finally drove it! Man it sound so mean. Here are the current pictures.
http://img.photobucket.com/albums/v6...s/PB100053.jpg http://img.photobucket.com/albums/v6...s/PB100052.jpg http://img.photobucket.com/albums/v6...s/PB100051.jpg http://img.photobucket.com/albums/v6...s/PB100049.jpg http://img.photobucket.com/albums/v6...s/PB100048.jpg |
So after drive my baby for its first weekend out, I blew my head gaskets. Not my fault!! Its my dads fault for not realizing that the engine needed all new gaskets.
http://img.photobucket.com/albums/v6...s/PB160074.jpg http://img.photobucket.com/albums/v6...s/PB160075.jpg http://img.photobucket.com/albums/v6...s/PB160078.jpg |
I will be posting phase two "Lifting my 72 K20" in the 4x4 threads.
http://67-72chevytrucks.com/vboard/s...d.php?t=267790 I'd just like to thank Stan, Mark, Jeff, and Terry at Early Classic Enterprises. This project wouldn't have happened without them and there help. |
you have all 4 hub caps or just the fronts even
would you want to sell them
I've been thinking about it. I'll keep you in mind if I do decide to sell them.
Were is the rest of the build? lift pictures, anything
Nice truck! Anymore info on that K10 in the pics?
