Rear bag ?
What bags are you guys running with the rear trailing arm set-up and how do you like it would you have ran another bag. I already have firestones in the front and was just gonna run the identical bag in the back but thought Id ask 1st. BTW I have the 2600's in the front.
Re: Rear bag ?
Some of run slam bags,I have slams up front and out back.
Re: Rear bag ?
I had 2600's on the rear of my 68 w/1.5" blocks. For reference, @ ride height the top of the axle tube is inside the frame rail 1" & the pumpkin barely peeks through the hole in the bed floor. This was about 30psi of air & I felt the ride was 'bouncy'. I needed to increase pressure to about 35psi min to smooth out the bounce but that raised the rear (too much rake).
I swapped to some smaller RE-6 Slams as well as some home-built 2" blocks. My logic is the slightly smaller bag will require more air psi for the same overall height which should eliminate the bouncy ride w/o the rake. Unfortunately I haven't had it back on the road to confirm my theory. |
Re: Rear bag ?
im running re7s here
Re: Rear bag ?
2,600 in front & 2,400 in rear ....
Re: Rear bag ?
im noticing not many people running slam specialties or other bags designed for airride applications why is that? just personal preference? ive always kind of wondered this you even see on the tv shows they hardly ever use slam bags
Re: Rear bag ?
I bought RE7s for the rear, but will probably go with F9000's sleved instead.
Re: Rear bag ?
Slam RE7's here.
Re: Rear bag ?
Re: Rear bag ?
I used F9000 sleeve bags. Put the bags behind the axle. Love 'em.
Re: Rear bag ?
Re: Rear bag ?
Big fan of your work man. Keep it up |
Re: Rear bag ?
Yep, you have the right idea. You can use schrader valves as you described.
Re: Rear bag ?
Is that the absolute most ghetto way to do it, or has anyone else did that for a few months attempt while saving for teh compressor and lines???? I just dont want to have to take the bed back off. |
Re: Rear bag ?
Re: Rear bag ?
I have a shrader on all my trucks air tanks... it is just handy just incase the compressors crap out on you or somethin.. Just run a T the two sides would be your bags then the other would be the shrader valve... you could run a cross if you wanted a gauge on it also.... just a thought
Re: Rear bag ?
Re: Rear bag ?
