my project (84 gmc)
Im building up my 84 GMC truck, as of right now the engines being built. It is a smallblock Chevy 436in with Eagle 4'' forged crank, Eagle 6'' H rods, Je pistons dome 4.165'', custom ground cam, Brodix heads w/2.08 intake and Brodix single plane highrise intake both port and polished to match each other, also a 1050cfm carb. The trans will be a built up th400 and the rearend will be a 10bolt with Auburn chunk and Richmond 4:10 gear ratio.
As soon as i can i will post picks of the build. I have a pic of the truck and once i get back home hopefully i will have the pics of the engine getting built. |
Re: my project (84 gmc)
Sounds like it's going to fly
My engine builder said it shuld be in the mid 12s. All it will have is close to 550+ hp and over 500ft/torque. Then later im thinking of getting a 84 s-15 and put it there. But thats still in the air.
Nice project...!!
thanks its been a long time comming. as soon as the engine is built we going t bring it to have it dyno then im going to put it in my truck.
thats still a long way off |
Keep the full size! It won't be as fast but 10x cooler!
thats a good idea also
does anyone know how much a Dart Little M block is.
With 550hp (at the crank) and 500ftlbs, I think it will go faster than mid 12's with the right set up.
With my converter locked, mine made 410rwhp/366ftlbs and unlocked (which yours will be) 386rwhp/366ftlbs. At 3,840 lbs with me in it, I went 12.33 @ 110mph. I can't imagine you having a 164hp/134tq loss through the drive train. |
if i get the dart block which i might do. if i do get it i will have lot more hp
call Jimmy Crenshaw in south Alabama I here he gets real good prices on dart stuff. 251-302-0100
will do thanks
if i get the Dart block i will get a bigger cam and add a 250 shot fogger system. |
After shipping...around $1,900....anything less is a good deal. If I had it to do all over again, I would try to find a good used one or even a bowtie block from racingjunk. The casting is pretty thick so they rarely crack, unlike factory blocks. |
when i get home from work next week i will be getting a dart block.
Let me know if Jimmy saves you any money. I need to buy a big block one myself!
the guy thats building my engine said he ould beable to get my block for me.
k theres been many changes and im sure there be many more. my engine builder just ordered my block, it will be a world product block. the reason he sayed was cuz it will need less machine work on the block for the 4.00' crank plus it was cheaper. its takeing a long time(money issue) but im sure i will love it once its finish.
