Engine Clean up
I was asked for pics of my set up. I looked as I thought I had posted them, but, no I can't seem to find them, so, here it is again..
http://73-ls1.com/63truck/cleanup/intake_n20.jpg http://73-ls1.com/63truck/cleanup/intake_n20_2.jpg http://73-ls1.com/63truck/cleanup/intake_n20_3.jpg |
Re: Engine Clean up
Now just drop that thing in my C10....ha!!!
Looks GREAT....anxious to see how it runs..... more videos PLEASE!!!! |
Re: Engine Clean up
Clean man, nice work.
Carbed LSX = 10 cool points |
Re: Engine Clean up
they were here:
http://67-72chevytrucks.com/vboard/s...d.php?t=297043 btw that engine looks pretty sharp |
Re: Engine Clean up
I knew I put them somewhere on here.. Oh well..
Re: Engine Clean up
How much motor HP are you "guess-timating"?????
Re: Engine Clean up
Is the plate perimeter with a crossbar ? NX ? Setup single or dual stage ? Have you left on dope yet ? Which hits harder the crossbar or the flush ? looks like the only way it can spray is all or none .
Re: Engine Clean up
The motor makes 430 to the wheels. The first hit will be jetted for a 100horse hit and the second stage for a 200hit. I am hoping to use both stages at some point down the track.
I have not left on the bottle as I haven't made it back to the track yet. Truck is apart. The plate in the pic is the perimeter+cross bar plate. I actually sent the plate back and they are sending me a dominator plate. This is pretty much the kit http://store.summitracing.com/partde...5&autoview=sku Here is a better pic of the plate http://static.summitracing.com/globa...ex-np957_w.jpg |
Re: Engine Clean up
Wow cool plate . Wait till you leave on a 100 shot . You'll be hooked . You get that thing to 60' under 1.50 and you'll get the rollbar speach .
opps , you already got that speech , I see it in your sig now . |
Re: Engine Clean up
I have a speedtech plate for a dominator that I want to sell. Then add a fogger for the second stage.
Re: Engine Clean up
whats the $ for the plate DJ, just wondering cause i might pic that up off ya
Re: Engine Clean up
350 With solenoids and solenoid mounting plate and two short lines that go from the noids to the plate with jets up to a 500hp shot!
Re: Engine Clean up
this is what it looks like but it has the lines and jets.
Re: Engine Clean up
ok.. TB finally came in today.. Also, I switched out the 4150 plate for a dominator plate. Was like $19 more or so.. Also, NX's customer service rocks.. I mentioned I was using this in a 58psi fuel system (LS1) and they had me send the carb jets back and set me ones for my fuel pressure. Let's just say the NOS kit I was going to use, when I spoke to their cust serv department, I'll never order from them again!!!
http://73-ls1.com/63truck/cleanup/TB01.jpg http://73-ls1.com/63truck/cleanup/TB02.jpg http://73-ls1.com/63truck/cleanup/TB03.jpg http://73-ls1.com/63truck/cleanup/TB04.jpg http://73-ls1.com/63truck/cleanup/TB05.jpg |
Re: Engine Clean up
Thought I'd share a few more pics of the intake setup I am switching to.. I also marked on both the intake opening on the Super Vic and Vic JR that I have with the Felpro gasket to give you a better understanding of the port differences. Hopefully I don't loose too much bottom end. But then again, the 4,900 verter probably won't care..
What fuel rail looks better? The black one ot the Edelbrock one? I know I need to do something about the valve covers.. http://73-ls1.com/63truck/cleanup/engine01.jpg http://73-ls1.com/63truck/cleanup/engine02.jpg http://73-ls1.com/63truck/cleanup/engine03.jpg http://73-ls1.com/63truck/cleanup/engine04.jpg Here is what the gasket looks like against my heads.. Also looking down the intake port while sitting on the motor: http://73-ls1.com/63truck/cleanup/headtogasket01.jpg http://73-ls1.com/63truck/cleanup/headtogasket02.jpg http://73-ls1.com/63truck/cleanup/portpic01.jpg http://73-ls1.com/63truck/cleanup/portpic02.jpg http://73-ls1.com/63truck/cleanup/portpic03.jpg Here is the height of this set up: http://73-ls1.com/63truck/cleanup/height.jpg |
Re: Engine Clean up
Finally the Vic JR vs Super Vic gasket..
http://73-ls1.com/63truck/cleanup/vicjrporttogasket.jpg http://73-ls1.com/63truck/cleanup/su...rttogasket.jpg |
Re: Engine Clean up
Looks GREAT.... nice pics.
So WHEN is going to be the "Debut".... you have "all" of us anxious.... and PLEASE .... "IF POSSIBLE" ..... new videos !!! |
Re: Engine Clean up
How much is Alchy running out there?
Re: Engine Clean up
No idea.. this is a pump gas motor when not on the bottle..
Re: Engine Clean up
Re: Engine Clean up
Man I'm 5 miles from Memphis but its high at mmp and speed shops around here all they sell is VP
Re: Engine Clean up
Was looking around here and came across this thread you started....
What is up with the engine, etc???? |
Re: Engine Clean up
Not sure if I get what your asking.. But it's the same long block that was in it for the 11.95 NA pass and 11.28 small hit pass. It's just getting a new intake and a different N20 system.. Sill need to put it back together.. The intake required gasket matching the heads. So I pulled the valves out and opened up the first 3/4" of the intake port.
Re: Engine Clean up
what brand is that throtle body and were did you get thanks
Re: Engine Clean up
Edelbrock, Summit..
