Need Sheetmetal help...
The shop just called and apparently they are having trouble locating a source for floor panels for my '72 Suburban. Does anyone know of any sources off-hand? Unfortunately, I haven't seen the truck, so I don't know which pieces that they need.
Thanks, |
Re: Need Sheetmetal help...
If its from the B pillar forward then the truck panels will work if your talking from the B pillar rearward I do not think those are reproduced. Hopefully I'm wrong but I don't think I am.
I later found out that he needs both front and rear. I will at least let him know about the fronts and I guess someone will pipe up if they know of a good option for the rear. |
I've never seen them made for the rear.
I guess that my only other recourse would be to find a good set of originals and have someone cut them out. Around Ohio, they wouldn't be much better, I'm sure... Also, I wonder how far off the '73-87 Rears would be and if they are available? At least it would be better than grafting in a Stop Sign, which will probably be the third tier down on the option list... Thanks for the help, |
