tranny problem
i have a 2000 GMC 1/2 ton truck with auto overdrive..
the problem i am having is... at cruise speed the transmission will shift up and down... doesnt seem to be slipping... but maybe the lockup is going in and out.... anyone here have any ideas.... plz thanks Rich |
Re: tranny problem
sounds like a pressure control solenoid
Re: tranny problem
Sounds like auto's suck.
Sorry that was mean. |
Re: tranny problem
Hold the truck at 55mph, gently push the brake (just enough to turn on the lights but not enough to actually apply brake). That will kick off the converter, note the tach reading, let off the brake, the tach should drop 3-400 rpm. that's the TCC engaging. If it doeen't, that's bad, next you'll need a scanner to determine if it's getting the signal, if it is, then it's the solenoid in the trans or a trans/converter problem.
Re: tranny problem
Re: tranny problem
all of these 99 to date are fully electronic.
Re: tranny problem
They all work the same. Brake shuts off TCC. ECM/PCM commands it on.
Only odd one are early units, particularly diesels, where the TCC may be hard wired to 3th gear or thru governer pressure. |
