vin on frame
I was just wondering where the vin was stamped on the frame at. I thought they were on top of the frame on the pass side under the door. Am i wrong?
Mine is located on the top of the driver side rail, right next to the steering box:bowtie:
ive got one by the steering gear and under the cab on the drivers side
There is a number there but it's starts with a oj something something.
thats probably it,
0- 1970 J- assembly plant (maybe, dunno if there was a J one) |
Heres the number if you can help me. OJ153074.
anyways, 0-1970 J-Janesville 153074-sequintal model number (53074 unit built) to get the rest of the info you need the total vin, like off the cab or glovebox, like mine is: K- 4 wheel drive E- came with a V8 2- 3/4 ton 4- fleetside box 1- 1971 S-St. Louis 673757- 573757 unit built im pretty sure that they started out with 100000 as first one built every year on the unit built number |
Yes they only stamp part of the serial # on the frame on the top of frame right beside or behind a little of the steering box. Its on the top of frame. Randy
Like said on Driver side upper frame rail and upper frame right under cab,b both mine reside on 67 GMC frames which came without vin on the frame,which makes it nice when i moved here and had to go through inspection on my 69 they Motor Vehicles looked everywhere didnt see any signs of tampering and were mind boggled going by the book,i just acted like I have no clue?after about 30 minutes of crawling up and under they just passed me.:eek:
