crossover steering
anybody with pics of 67-72 using 2wd box and crossover steering?
Re: crossover steering
I can take some a bit later, if you need. Burt posted quite a few of his, in this forum.
http://www.norcalbigdawgs.net/Galler...sst1.thumb.jpg
I had to run a shorter pitman arm, WFO provided it, I think is is from a Full-Size Wrangler. I have High-steer w/low lift and a BBC so not much room/space. In a none High-steer setup or a bigger lift you prolly won't need a shorter pitman arm?? Each setup seams to be slightly different from the next so..get parts and keep building until it's right hehehe:lol::mm: |
I used a later model Dodge pitman arm for my crossover.
Here is my custom cross over steering on a Dana 44.
Custom Crossover steering OEM 2WD Steering Box Jeep YJ Pitman Arm Custom DOM Tubing Tie Rod with Hime Joints Passenger Steering Arm ProComp Dual Steering Stabilizer http://img.photobucket.com/albums/v6...s/PC220140.jpg http://img.photobucket.com/albums/v6...s/PC220138.jpg http://img.photobucket.com/albums/v6...s/PC220135.jpg |
Mine is using a 2wd box stock tie rod bent to use for the crossover bar.
http://i18.photobucket.com/albums/b1...2/e850697b.jpg http://i18.photobucket.com/albums/b1...2/ecbb8b43.jpg http://i18.photobucket.com/albums/b1...2/32e9328e.jpg |
I know this is an old thread, but thought I would pull it up to see if there is any updated info on this. Any systems out there on a 4" lift, 67-72?
What exactly are you looking for? Pics, info, 1/2t, 3/4?
Posted via Mobile Device |
Yeah I think you'll have plenty of clearance. On 73- trucks, they can have clearance issues with the motormount crossmember. But the 67-72's are different.
Thanks guys,
Will be sending my knuckle to WFO soon as I get back home and finally be able to get back on my blazer. Blazerman, as far as the steering arm, is that a 1.5" or 2" arm with you 4" lift? I'll be using WFO for all the crossover parts, a little cheaper than ORD, and Red Head for the steering box. Thanks again for the info |
Blazerman what is your steering shaft setup?
http://i3.photobucket.com/albums/y65...D052E77F4A.jpg My wfo setup with 6" leafs Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
So those with crossover, hows the onroad behavior?
