bbc s10
how much harder is it to bbc a s10 rather than sbc one? can it be done with out crossmember mods and such?
Re: bbc s10
i dont think its so much the high but the width... bbc are crazy wide and to get them between the frame rails would need alot of fab skills... but i would love to see it personally.. what gen s10?
Re: bbc s10
1st gen its a 87. i just bought a slammed s10 with a rod knocking v6 and have both a sbc and bbc sittin in my shop i would love to bbc just wondering if it could be done.... has anyone seen this swap...
Re: bbc s10
With the right oil pan, I see no need for frame mods. Most of the width of a BB is above the frame rails. The one I seen had stock cast iron exhaust manifolds, and really didn't seem much more crowded than a SB S10 to look at it. I mean as far as working on it, it seemed like it'd be about like a SB truck. Depending on the exhaust ya choose, that area may require some frame massaging, but I couldn't say for sure. |
Re: bbc s10
I've only done sbc conversions, but there's a guy down the road that had to do extensive firewall work. He finally decided to make it a strip truck because of the hassles he faced. I keep hearing 2 different stories on the bbc conversion. Try this link, it has a wealth of information including part numbers and what not for a clean factory looking BBC in a 1st gen s10
http://www.s10forum.com/forum/f10/1s...lation-223375/ |
Re: bbc s10
Small blocks barely fit...Big block is a dream, and definately would involve MAJOR fabrication unless you run your exaust through the hood lik a pulling truck. You can build a small block with as much power, cheaper and still have about a hundred pound weight advantage. my.02
Re: bbc s10
well if its an 87 then you have all the room in the world and it shouldnt take much to fab up some mounts for everything... i was thinkin more along the lines of a early 90s+ blazer for some reason.. maybe im still stuck over at s10forum.com... they might be able to answer you question a little better since they have a 1st gen spacific forum..
Re: bbc s10
Re: bbc s10
agreed
Re: bbc s10
do it. it may take time, you may loose all your hair, your gonna have your ups and downs but when said and done an s10 with a big block will stand before you:devil:
here is some inspiration.......get to work:metal: http://www.minitruckinweb.com/featur...zer/index.html http://rides.webshots.com/album/559709504pmJxMV http://sporttruck.automotive.com/968...s10/index.html |
Re: bbc s10
as far as bbc weighing more and all that i dont think it matters. ya you can build a same hp and tq sbc as a bbc, but bb are way more fun in my opinion and with the same power its gonna be way more streetable. after i took out a built 383 outta my 70 gmc and put a mildly built bbc in it was still way more fun. ill never do sbc again
Re: bbc s10
www.s10v8.com |
