Project "El Cid"
5 Attachment(s)
Well, I started!!. Sold the 454 that was in the 72 tuck an bougt a 5.3 Vortec engine from a 2007 Chevy Silverado. Only paid $1,400 for the whole engine, harness, DBW pedal, and cruise control, MAF sensor. ALL the accesories to include, starter, power steering pump, alternator, and A/C Compressor. The engine only has 16,000 miles on it!!! Sweet!!
All I need now is the Motor Mounts, Cross member(I'll make this one), Exahust(modifying the current exhaust) Air filter, Electric fans, and ECU/PCM retuned. If anyone has sugestions or Time saving tips please forward them to me. I have been all over these Forums and have lots of information. but Kowledge s power and applying it is victory!! Here are some pictures of what I have started!! Enjoy. This will be dedicated to all Navy Chief Petty Officers, Past, Present and Future!! |
Re: !!!!5.3 Vortec Swap Started!!!!
5 Attachment(s)
more
Sweet !!!!
Sweet man
Nice......what you doing for a tranny?
I will be needing some economical suggestions for headers, fuel tank/pump, tranny cooler, motor mounts, cam, and electric fans. So, If anyone has made this swap and has some suggestions please let me know. Thanks, Sick454 |
98-02 F Body headers seem to fit these frames well. I picked up a cheap no-name set on ebay for $180 new, and they are stainless
If you are leaving the A/C or aftermarket A/C in it's current position, cut the frame pretty much right where it is turned up in front of the passenger mount. Also, you can use the stock manifolds with just a little trimming on the frame as well. I don't have measurements, just take them off, bolt the motor up, and then mark where to cut. I did not try to go cheap on the motor mounts, I want them to last, so I purchased the ECE mounts and they work and look great.
You can kind of see where I cut and how it sits here, I need to do more trimming now that it is sitting in there. http://photos-d.ll.facebook.com/phot...50627_8488.jpg Orlando |
Thanks, Orlando. I plan to swap the exhaust manifolds for a set of headers and since the engine is out I want to replace the cam. Has anyone used the ECE mounts with headers(and what kind of headers)?? Shane |
Well, The weather this weekend was beautifull. So, I went for a bike ride! Instead of working on the build. I will be posting what I have gotten don't later next weekend. Sorry for not upadating you folks.
I pulled a 5.3 from an 02 tahoe and later realized that headers would stick way to far out. I wasnt comfortable with trimming the frame that much. Id say i had to cut a good 3/4 of an inch in a half moon pattern with the stock manifolds. I dont know if we could raise the motor or what but im def looking for a way to stick thoughs things in there. what computer are you gonna use? i ended up using a great one from redline. I also went with a solid 700R4. I was told by many that wouldnt work but it works perfect and way more fun than the 5 speed i had.
Shane |
Hi Shane,
Where are you findinng all these goodies at that are cheap? --$1500 for the low mileage 5.3L engine --$500 4L60E transmission with low miles Are you getting these from a local junkyard or what? Thanks, Adam |
http://www.lkqcorp.com/home/home.asp Good luck, hope they can help you out too. Shane |
5 Attachment(s)
more updates. with just a little progress. weather is finally good here in Kansas. Balancing good days with a chance to work on truck, or ride my bike? Which would you do?
4 Attachment(s)
More updates I still have to notch out the frame for the stock exhaust manifolds to work you can see they are still rubbing the frame. other than that everything went in pretty easy.
lookin nnice, i know all about the bike or work thing, but i normally work all day from 7 - 10 then go riding for 2 houtr at nite, my favorite time to ride, i do not sleep much, but i get the best of both worls to an extent
Any new updates?
Yes.... Actually the Homeowners Association for which i live in (I'm renting by the way). Has pitched a fit that my truck is an inoperable vehicle. Even thought there rules state the vehicle has to be tagged and insured, which it is. Co(K suckers!!!! anyway had to move it into the garage. So, Now i make sure I get up really early on Saturday nd Sunday mornings to get out and grind and hammer and weld and make as much noise as i can, so that everyone on my block knows that it won't be inoperative for long!!!!!!!!!!!!!!
As for what has been done. 1.) motor mounts are solid and complete. 2.) Trans mount is solid and complete. 3.) frame has been notched out and painted in the area that were cut to make room for the stock exhaust manifolds and A/C compressor. 4.) researching parts for trans cooler, p/s hoses, fuel pump and possibly new tank, Electric Fans. Any help with part numbers and manufaturs in these areas would be appreciated. I would like to keep the blazer tank that i have relocated to the rear frame if possible. just need to figure out the fuel delivery / return / pick-up. HELP !! I'm not looking for pretty here, just effective and reliable. Thanks, Sick454 |
