Shift Indicator Light
Redone my steering column. Auto, 2 speed
I found a little fiberoptic cable in there that ran up to the shift indicator. One end plugs into a light socket and the other end plugs up into the indicator. I cleaned everything good and put in a new bulb and expected to see a big bright lighted up indicator, but it did not happen. It's just a tiny little light that really doesn't help much. Is that normal? Is that just as good as it works? Maybe it will show up better in the total dark, but setting in the shop, I wonder why they even bothered. |
Re: Shift Indicator Light
LMAO I did the same thing ..subscribed to see what others say...kinda like my heater control light....
You may want to pull the fiber optic cable out and inspect, if it is frayed at all (like mine was when I swaped columns) it wont let as much light to the indicator. there is also a trick where you can put in a different bulb in your gauge cluster to make it brighter, but I cant remember the type of bulb. a bunch of guys do this just to make their dash lights brighter. hopefully someone will chime in with this bulb info.
I got mine working a while back and it's not spectacular, but it get the job done. I'm not sure I would want it much brighter, it would probably be distracting.
LOL.... |
yea why is it that the light for the heater A/C is on the other side of the controls oposite side of the fan which is what I wanna see ??...or is there supose o be a light on that side too??
The end of the fiber optic cable needs to have a clean cut end to transmit the light properly. Take a razor blade and trim the ends smooth and it will work better.
all heater controls, a/c or non a/c had lights.
Non A/C had a single bulb as described above, A/C trucks had 2 bulbs on the control panel, one left, and one right. |
:dohh: thanx Longhorn Man I thought I had something special with just one light on my A/C controls...now I have to spend more time on my back looking under the dash and find a second light socket
