73-80 vs 81-91 body mount differences
I did a search and didn't find what I was looking for.
I am just starting my 2wd blazer project. I found a '78 2wd with some rust issues and a 1988 4wd that has a great body. I am going to put the '88 body on the '78 frame. Can someone tell me specifically what the differences are between the body mounts, and which ones I should use for my project. Thanks in advance, and I will start a build thread soon. Mike |
Re: 73-80 vs 81-91 body mount differences
use the body mounts for the year of the frame
In 1979 chevy changed the blazer frames to give more rear leg room. The back seat platform on 73-78 raises just behind the front seat. 79-91 rear platform raises a foot or so behind the front seat...
Chuck |
Actually the rear floor change happened with the 78 model. That's why I was sure the 88 body would fit the 78 chassis. The 78-91 bodies will not fit on the 77 and prior frame.
I just wasn't sure about the body mount differences. The rubber mount design changed with the '81 body. |
I put a '87 4x4 body onto '73 2wd frame and besides the floor differences which you don't have to deal with I don't think I ran into any other problems swapping it over. I used body mounts made for the '87.
Good to know in case I need to swap the body of my 77' (with no title)
Bringing one back from the dead...
I'm with ECU pirate - if I decide to swap my straight '77 body onto a '79 frame, what problems will I run into? Looks like the other way around would give problems with frame being in the way of the footwell, but other than a lack of support under the seats, any other issues I might run into? |
I'll fill you guys in on this in a couple of weeks. We bought a 78' k5 with a shot body, and found a newer 80's body in a yard. We are going to bolt up the 78 parts on the blazer before paint. Trevor
