v8 swap question
Hey all, I have a 93 Bravada that I am putting a 383 into and I have a few problems. The main one is, with the correct oil pan and motor mounts, no matter how much I try to add in spacers, the oil pan still sits on top of the front differential. Is there a different set of mounts that I should use? Different oil pan? Help... this is getting irritating. Thanks!
Re: v8 swap question
http://www.v8s10.com/Pages/Parts_S10-4x4OilPan.html http://www.v8s10.com/Pages/Parts_S10-NewOilPan.html http://www.summitracing.com/parts/ADD-716411A/ http://www.summitracing.com/parts/HAM-1099/ What motor mounts are you using? EDIT: I just reread your post, you said you are using the correct pan, which one are you using? |
is the AWD t-case and front axle setup the same as the standard 4x4? that'd be the only reason I could see...
The front end is the same as the 4x4. The transfer case is what makes it awd or 4x4.
i can't imagine why Big C could have problems if its same as standard 4x4. theres plenty of 4x4 s-10s out there....
Hey,
I am using the Advance Adapters oil pan, and JTR style mounts with 2.8 frame side mounts, if that helps anything. |
look like this one? http://www.s10v8.com/store/images/S10V8PAN.jpg
Yeah, that's the one I have.
Could you post some pictures of what you have?
