Satin / Flat / Matte Black Paint?
Has anyone painted their ride satin, flat, or matte black. I would like to see pics and know what product you used.
Re: Satin / Flat / Matte Black Paint?
hotrod flatz makes satin paint (read, NOT PRIMER) in tons of different colors. I've heard mixed results on the quality. You could also get a flattener added to the clear for a satin look.
flatening agents will make the paint porous like primer and will not hold up. make sure whatever you use is a finish SEALED paint. We prefer Sherman Williams Polane for low gloss finishes especially our chassis black
Here is one I did. I used a bc/cc with satin clear. Just the red, the white is single stage, it has a little more shine than the red.
http://i8.photobucket.com/albums/a1/...g?t=1268883447 |
what poduct is the white?
I am thinking about going with SEM hot rod black. I see that hot rod flatz has many colors to choose from, but have heard quite a few mixed feelings on the product. I like that red btw. |
If you are going black...just use Rustoleum in the quart or John Deer Blitz Black. Its cheap and is an industrial paint. Here is a 66 Mustang I painted with Rustoleum about 2 years ago and it sits outside...looks the exact same as it did when I painted it. I have like $30 into paint.
http://i59.photobucket.com/albums/g3...g/IMG_0762.jpg http://i59.photobucket.com/albums/g3...g/IMG_0760.jpg |
to spray, thin rustoleum industrial with acetone 1:1 ratio
Rustoleum is a rubberized paint. you will have a hell of a time if you ever want to sand it or paint over it.
I've been considering going with a satin black for my truck as well. I've read mixed reviews about using a single stage, base by itself, or a base/satin clear. My painter buddy doesn't want to paint satin black because you can't sand it after your paint, so basically if you get any runs or trash in your finish you have to sand then re-paint.
http://i283.photobucket.com/albums/k...w/IMG_4906.jpg
Used Hot Rod Flatz... I have mixed feeling about doing a flat paint job, only because it my first.. |
Well it looks like it came out nice.
Eastwoods rat rod black satin.
Rochlow - that looks mean and nasty - exactly what I am looking for! Did you go single stage, an epoxy primer, a base alone, or a base/satin clear?
how did the flatz spray. I have heard some bad things about it not laying down well. Did you use more than a gallon?
I am REALLY close to ordering the SEM Hotrod Black kit. too bad it only comes in quarts. NICE looking truck btw!!! Keep em coming guys.... |
I used n.a.p.a farm paint but is going chalkey but was cheap and it helped me learn how to spray,no pro but how to set gun etc.I should of put some satin clear or what ever your suppose to use after, but I didn.t,I think the flat black paint has ran it,s course, here anyway, everybody and their dog is painting flat black,from spray bomb to real nice
The kit came with a gallon of base, a quart of hardner and a quart of reducer. Which made a gallon and a half of sprayable material. It took pretty much all of it to do the one coat on the inside of the entire tube and two coats on everything else
The tech sheet said to spray two wet coats. We sparyed the hood first and had some issues with the gun that we had to fix and ended up spraying three coats on the hood. Now looking back I wish I would have sprayed three coats on everything as the finish is still a matte finish, but it is just smoother with three.. I'm used to be really picky when it came to paint, but I have to keep in mind I'm building a hot rod style truck, not a show truck. |
any reviews on kirker products.
