Should I leave the Fuel Tank in the Cab?
Those of you who have moved it or kept it, tell me what you think. Pros, cons for each option. Pics!
Thanks in advance! |
Re: Should I leave the Fuel Tank in the Cab?
Its much easier to just leave it in the cab. LOL.
Seriously though, when my tank in the cab is full it is noisy and I sometimes smell a little fuel. I think the noise is from the sides of the tank flexing. It would be nice to have some more room behind the seat as well. |
I left mine in the cab so I could put my spare tire under the bed.
Only thing I dont like about my blazer tank is:
PITA filler No spare tire place (except putting in bed, that looks ugly but its a truck oh well) |
Filler is the pain, I have a billion vents and it still wont fill fast.......Hate poly tanks. Smitty |
they've worked fine for 40years have never seen a need to move one
Unless you need the space behind your seat for something other than gas leave it there. I have a million more important things to spend my time on than moving something that works perfectly well.
leave it in the cab. I moved mine and it was such a pain to fill that I put it back in the cab.
I would consider moving it if there was a reason other than speakers....Dosent gain me any more leg room so its just extra $$$ and trouble I can spend elsewhere.:)
When we redid my truck I did not see any real benefit as to moving the tank to under the bed. I never smell any gas in my truck not did I fing it necessary at all..
I probably will never move the tank out of the cab, no advantage that I can see since both my trucks have bucket seats.
Having a tank in the cab is part of the old trucks. I am more into original workable trucks myself, but I do appreciate all the work that people have put into their trucks to make them the way they want. |
I left mine in the cab after some modifications. I had 3 bungs soldered into the bottom of the tank so that my high pressure fuel pump mounted on the frame for the fuel injection wouldn't be starved when I turned a corner. I removed the sock from the original fuel line from the sending unit and use it as a return line. Works great.
Attachment 614666 |
When you added the sound deading material how much did it knock the noise level down vs. stock? 1-10 (10 being loud) I would say the truck is a solid 9 now...lol:devil::waah: |
Ive always been told it was more of a safety issue, is there any truth to that?
I would leave it personally. I don't recall many ever being wrecked and having problems as far as a safety issue and as far as smelling gas I smoked in them for years:lol: I am one of those weird ones that don't mind the smell.
Unless you like the looks better I would just leave it. |
The one I'm driving daily will stay in the cab, my son's with the blown BBC will go under the bed, for added traction if nothing else.
With a built 406 and the windows up the sound is about a 4-5 with the windows down is about a 7........it definetly made it alot quieter..... |
i moved mine. i didnt like the fuel smell or the sloshing. mine fills great no problems at all. now i have room for my tool box out of sight.
David....I guess since I asked about this in your other thread, I should comment here....keep it in the cab:D
Mine is still in the cab and is staying there.
The one time that I have had gas fumes is when the seal on the sending unit finally rotted out. A new one from Classic parts solved that, and I haven't had any gas odor since. |
I moved mine and like it....but it was a PITA, I would never do it again.
I don't want to move my tank... But I want to shave the filler.
Sucks.. :( |
I moved mine and I love it. I did it at first for safety reasons since its my daily driver and thats the last thing I want to have behind the seat in a crash. I did notice a major improvement in ride quality once I put mine in the back. Also like mentioned before you will get some added traction in the rear. If you do change gas tanks, I highly reccomend using a 1969 Camaro gas tank if you do want to change yours to the rear. It lets you hide the filler neck behind the license plate (no holes in the bed), the fuel sender works with the gas guage, and it does not hang down hardly at all compared to the Blazer tank conversion (Also its cheaper than the blazer tank).
Every once in a while I get a wiff of gas when the tank is full and it"s hot outside, but I like it. If you don't like the smell, add some 110 octaine. lol... seriously, if the sloshing bothers you, your exhaust is to quiet....
I like the gas filler where it was from the factory, I think it"s cool! Either way, it is an old truck and that is awesome. |
