'67 C10 Shorty Stepside
5 Attachment(s)
Combining two trucks with this one, a 67 short/fleet originally will be getting the body panels off my 68 short/step. (68 project to come later!) PIcked the 67 up super cheap a few years ago, no front clip/motor/trans/interior/ beat up bed...the works. Cab was in rough shape down low, couple other spots on the Roof and firewall showin some cancer as well. Gettin that all Fixed up now (not my favortie part by any means) and it's taking a while but got the project back in full swing now. so hopefully I can make some progress! PIctures below are of the truck as it sits now. Going to get some older ones up as soon as i figure out what i did with them....
As it sits: Frame stripped, cleaned, adn painted (Dust Covered as hell in the pics) Rust Repair on Cab Started Early Classic 4/6 drop w/ Relocated shock mounts, Super track bar, Extreme Drop X member, KYB shocks, Disc brakes up front, Fr/Rear Sway bars, Urethane all the way around,All new Steering Parts, New brake lines. Completely Re-built 12 bolt T w/ 4.11 & Powertrax, Stock axles (almost worried i didn't spend the extra cash there...) Completely new Rear Drums, No E-brake. Planned: Repair,fill, and smooth cab/firewall (exc door handles) New fenders, Hood, Core support, wheel wells, bumpers, steps Using All bed panels and doors from 68 (stripping down all the way), Grille from '67 (still in amazing shape surprisingly) 406, full roller, 12.5:1, AFR heads, Eagle Rotating, Comp valvetrain.(ALL NEW) TCI TH-400 Tranny (from 68) Interior--black reworked stock bench, carpet, vinyl doors, dash pad, visors, from 68, Brothers Gauge cluster w/ Autometer Phantoms, Heater removed. All custom sound, lighting, and wiring. Copperhead style fuel tank w/bed fill, New wood floor mush more i'm forgetting to list i'm sure... |
Re: '67 C10 Shorty Stepside
5 Attachment(s)
Here you can see some of the Repair work, and just for the record that spot on the Roof looks like hell... i know, It's a pain in the butt! but we'll get it looking good!
Daaaaaaang! Looks like you gotta lot of work ahead of you!!! Call me if you need beer!:metal:
well,
your girlfriend or wife will miss you. doesnt look like a bad start |
O i need beer! NOW! and no girl to sit around and miss me at the moment... perhaps i'll round one up while i'm in the middle of this and she'll know what she's in for from the get go!
Gotta take a couple week break from it for work right now, but i got the bedsides stripped down and the undercoat removed from them (UGH!) puttin up more pics soon! and Portmod... where's your build thread huh buddy? |
I work on my truck like I snowboard, about once a year. I didn't figure putting up pics once a year would be very productive or interesting. Maybe I'll just post everything at once, when it's done, around 30 years from now... :dig:
Now I'm subscribed, I expect more progress notifications than I can stand...
I wanna see MORE!!!
:clap: Posted via Mobile Device |
5 Attachment(s)
OK, getting back on track and really excited about it. A little progress has been made since a whopping two years ago when I started this thread, but by no means has two years of progress been made :( .
I went out tonight, and finished my note list I've been working on the last couple days, which includes my Plan of Action, what parts I'm needing immediately, and some questions I need to answer before X point in the build. So I have a good solid plan going on now, definitely on a much better course than before. Now if I can just push through the hassle of this body work, it should be fairly smooth sailin! In the two years since I started this thing, my outlook on mechanics, design, and craftsmanship, has changed dramatically, Influenced, in no small part, by Portmod7, and my time spent workin on race cars over the last two years. My skills have definitely made progress in the right direction as well, by no means am I master at this stuff yet, but I'm better than I was for sure. I look at a few of the things I did a couple years ago and just kind of shake my head, lol, some of that stuff may get changed for the better over the course of the rest of this build. I'll make a couple posts here with a few pics in each and give some info about what's been done, and where it's headed. Like I say, the basic plan of this build had changed a bit (as they all do I think), and since it'll probably keep changing as I go, I'm not going to worry about laying out a complete plan for you guys now. I'll keep you updated with tidbits as we go post by post, and by all means, if any of you guys have any questions, ask away! We all may learn/ discover something in the process! To start out, here are a few pics of how I got from two years ago to how it sits today. I got a set of Heater delete panels from Nate @ Porterbuilt, they are made great and fit very well (I wouldn't expect any less), And I fabbed the other small patch panels for the firewall and cowl myself. I'm not the best at sheet metal welding, and working with body filler is an art form that I’m SLOWLY understanding. All my patch spots have a little filler along the weld seems, but I've spent hours on pretty much every spot making sure everything is coming out smooth, with as little filler being used as possible, and I’m fairly satisfied with how it's turning out. |
5 Attachment(s)
Here's filling the factory fuse panel hole & repairing the rust spot on the cowl, that double wall cowl is a little tricky to work with at that spot, but it came out OK.
And i know it's not glassy smooth, but I'm not really going for that look, I more want it to look like it was made that way orginally, and if you look at the countours & spot welds & wrinkles all over the firewall, that thing is FAR from anywhere near flat. Just keeping the engine compartment as clean as possible is the ultimate goal. |
4 Attachment(s)
Couple more of the heater & fuse block area from the inside. I plan on making some inner panels on the firewall to mount all my electronics on, raised a little bit so I can hide all the wiring behind them.
I e-mailed Nate at Porterbuilt the other day about seeing If I could get another heater delete panel, except with an opposite bead roll so I could cover the inside area of the heater core the exact same way I did the outside. |
2 Attachment(s)
What's been cut out, and what's left to put back on ( think postiive..think positive....think positive....)
Good progress, just gotta keep plugging away. One small piece of the puzzle every time you get a chance. It'll come together! Gotta keep our Fo*d buddies from ganging up on us... |
Great job on all the metal work !
Oh boy does all that look familiar. :lol:
I see you smoothed out your firewall, have you decided what system you're going with, any at all or perhaps just heat only? My cab is non-ac, would love to smooth the firewall and put in some under dash heat... not sure aftermarket AC would be in the budget for me, but curious what your plans are? |
Thats a good start.
I will be following along and I'm looking forward to all the progress. I'm pretty sure the Vintage Air systems run in the $1300 range, which isn't too bad for what you are getting IMO. |
3 Attachment(s)
On that note, I'm open to suggestions on what to do with the wiper cowl where the windshield wipers would come out if they were going to be there. I could just leave the humps in the cowl and plug em with a slug, i could just leave em open and not worry with it, or I could do some worth of smoothing work there, I don't realy know which direction to head with it. So yeah, if you guys have any suggestions or stumble upon any threads with a similar situation, let me know.
Here's a couple more pics of how the truck was sitting last night when I left it: The pic of the wiper cowl is on another cab I have sitting around (obviously for along time, as the dust tells you) just using it for referance. |
Good progress man, I'll be following for sure :)
Hey just wondering. Won't the front lower part of the cab bend since you don't have the lower part of the pillar for support? I would tack something on their so it won't warp, but then again idk lol Posted via Mobile Device |
