6.0l Swap, tranny questions
I am real close to buying a 6.0l LQ4/9 and have tranny questions. I already have a built th350 and would like to run that behind it for now, I know how to mount it to the motor, but what about the kickdown cable? Is there a bracket out there for it? What do I do about that?
Re: 6.0l Swap, tranny questions
Your turbo 350 will bolt right up like any other engine/trans combo. You will need a flywheel spacer to mate the th350 torque converter to your 6.0 flexplate though. Cheap and on ebay as well. There are brackets and cables out there for the kickdown. Good luck.
Bowtie Overdrives carries te bracket to adapt the kickdown cable to the throttle cable.
