C20 lowered pictures
Looking for pictures of lowered C20 that are still C20's with 8 bolt wheels.
GMC Paul says he has sold many of the C20 lowering spring kits to members and I would like to see pictures. I would really appreciate before and after pictures as well as details on how much the truck was lowered and how. And yes I have searched for lowering of C20's but have found very little information. Considering lowering my 68 C20.......... |
Re: C20 lowered pictures
I've decided to keep mine stock, but maybe this thread will change my mind.
Do you have leaf springs in the rear? |
I have coils.
I am considering lowering the rear a couple of inches to level the truck out or 2" in the front with coils and 4" in the back. GMC Pauls sells lowering springs for C20's. http://www.gmcpauls.com/lowering_springs_&_parts.htm 63-72 3/4 Ton Front Lowering Coil Springs Pair 4145722 For 67-72 3/4 ton trucks, Heavy Duty High Performance Front Lowering Springs Available in 1", 2" drop. Sold as a calibrated matched set. These are not cheap imported car springs like others sell these are custom made in the USA and are calibrated matched sets made specifically for the truck they will be installed on. $129.95 63-72 3/4 Ton Rear Lowering Coil Springs Pair 4145732 63-72 3/4 Ton truck Heavy Duty High Performance rear lowering springs. Available in 2", 3", 4", 5" or 6" drop. Sold as a calibrated matched set. These are not cheap imported car springs like others sell these are custom made in the USA and are calibrated matched sets made specifically for the truck they will be installed on. |
Coils seems much easier to do. Are you concerned about ride quality with the drop? I definitely think these trucks looks nicer when they are level. This means wheels and tires also?
3 Attachment(s)
Heres a few from my collection of pictures
bttt as someone on here must have a C20 that has been lowered......
here are some pictures of mine. I lowered it the cheap way, cut coils in front and pulled 4 leaves in back. This combo got me down 3" in front and 4" in rear. I still can haul with it but anything over a ton in the bed and I'm on the bumpstops (most I've hauled since drop is 3500#'s of gravel). More details here.
BEFORE (Sorry about the crappy pic, it was my cell phone but you get the idea.) http://i256.photobucket.com/albums/h...nepics3020.jpg AFTER http://i256.photobucket.com/albums/h...nepics3021.jpg |
Alright 1st post. Sorry no picts yet. Truck still on jack stands in process of rebuild. 72 GMC LWB C20. Rear drop of 4" had leaf springs dearched too maintain load capabilities($225). Front 2 1/2" drop spindles from Performance online($400). Complete rebuild of steering from Performance online($357) new shocks all the way around POL($200) and slotted vented rotors from LMC($270). It has not been too difficult just time consumming and I only know enough to get my into trouble mechanically. This site has been very helpful. I can't wait to get rolling again. Picts too come.
top for ya
4 Attachment(s)
Heres mine. 3" drop spindles from airbagit.com,cut 1/2 a coil. Changed rear from leaf to coil cpp c-notch and used ECE 6" drop coils and 2" blocks.
Dont have any better pics right now since im deployed and its been 5 years since i messed with it but PO cut the coils in the front and i believe extended the hangers on the rear, i want to keep it 8 lug and bag it to lay frame, as of right now you put any weight in it and everytime you hit a bump it bottoms out
Gofast68c20, hows the ride with coil rear compared to the leafsprings? I'm thinking of doing this as well. Thanks.
I am hoping to pick up my new frame and suspension this week. I'll post pics of my 69 C20 lowered if all goes well.
2 Attachment(s)
Here is a pic of my recent purchase. Had the truck about a month or so. I am not sure how much it is dropped. I did find out today that I am riding on the rubber bumpstops up front, so I may cut them or remove them completely.
Oh yeah, coil suspension all around, and drop coils were used, as I was given the stock coils when I bought it. |
Before
http://www.northbayautorepair.com/images/truck1.jpg After http://www.northbayautorepair.com/images/truck32.JPG http://www.northbayautorepair.com/images/truck35.JPG Front Coils were cut (2 coils), which was too much, as I have about 1/2" inch of clearance right now. I think 1 coil would be better if you feel that you need to go that route. Rear axle has been flipped on top of the springs. |
Looks like the pic didn't copy. The green and white one. |
Mine wasn't lowered, but leveled - I'm not sure how it was done but I liked the way it sat.
2 Attachment(s)
Heres some pics of my 68 C20, not really what your looking for i did a half ton conversion to 5 hole. About 16'' lower than when i got it and still might be going lower
http://modesto.craigslist.org/cto/2466735965.html
I'm still thinking about it, but it has leaf springs in the back and I want to eventually do airbags. Anybody make bolt-in stuff to do some sort of 4 link setup or other setup to run airbags on this thing? Fully optioned Sierra Grande for cheap with a straight body you can just spray for a lot cheaper than a shortbed will run... |
4 Attachment(s)
Here's some updated pics of mine. Original plan was to lower it with springs, after that decided i wanted it lower so i bagged it. Dominator 2600's with Accuair control. Its currently apart awaiting an 8.1l transplant!!
Here is a before pic, this is how it looked when i bought it.
How much did it run you to switch to coils? Thats exactly what I want to do if I buy the GMC I've been looking at.
Switch to coils and then do the accuair with some heavy bags with no notch though. Did you weld anything or just take the rear end and everything from the donor truck? |
I used the trailing arms and crossmember over the axle from a donor frame. Welded new perches to the axle for the arms and cut the leaf spring perches off. The only things I welded were the c notches and the axle perches everything else bolted up.
Posted via Mobile Device |
