My GMC Sierra Grande: Project GOLDIE
2 Attachment(s)
Attachment 670932
Flat Black 1981 GMC Sierra Grande Long Bed 1978 350 Truck Block (3970010) Bored o.o3o over. (355ci) Intake Weind X-Celerator & Holley 750 4 brl vacum + Electric choke MSD Ignition + 8.5mm wires Lunati Cam 235/240 Dur.50 458-458 Lift GM Steel Crank Ported 441X Heads (Flowbench tested) Splyied caps Flat top foreged competiton Pistons GM X Conectting Rods Stock Oil pump modified for high flow. Aluminium High Flow water pump Isky Springs Manly Valves Lunati Hydraulic Lifters Comp Cams Rockers Comp Cams forged push rods Cloyse tx9 Timing Chain with Torrington bearing Hooker long tube headers Double Exaust from front to rear Cherybomb Mufflers 10.3:1 Compression Ratio 1973 Moncie M21 4 speed with Hurst RamRod shifter Locked AuburnGear rear end with 3.40 gears 275/60R15 Rubber on all 4 steel rims Custom Grill Custom Seat with Center console Stock painted pulleys Chrome Valve covers Milodon Oil pan |
Re: My GMC Sierra Grande: Project GOLDIE
More to come soon! let me know what you think.
Thanks! |
looks sweet man
2 Attachment(s)
Meet Pepper, my 80 flat blacker
3 Attachment(s)
A couple pics of the stock seat I custumized to my liking with Trans Am rear buckets a refurbished consol from an old Pontiac and some extra foam.
I got the thing wraped it Black imatation leather with white Stitching. I dont have picks on the finished product, ill try i get them soon. Attachment 671051 Stock seat strip and preped for revival! i kept the original foam and whent from there striped the rear seats from the trans am Attachment 671052 From there I measured and cut evrything to fit, I had to fab up a braket for the console. Glued my pieces together, used duct tape to hold everything in place While it dried. Attachment 671053 Once everything was glued, I slaped on on other layer of foam for look and comfort! |
5 Attachment(s)
ENGINE SWAP PICS
From 3o5 to 355 Attachment 671067 Me and a buddy rippin all the accessories out Attachment 671068 The motor had been changed before and everything was a real mess Attachment 671069 Moncie M21 preped for rebuild Attachment 671070 Talking out the old burnt out 3o5 Attachment 671071 Me prepin the egine bay for a new coat of paint and ripping out all the useless wiring:metal: |
3 Attachment(s)
ENGINE SWAP PICS CONTINUED
Attachment 671086 All sanded and preped for paint Attachment 671087 Fresh semi gloss paint Attachment 671088 New 355 CSB right before fitting it in the whole |
What size are your tires?
I do everything a can by my self, so questions often come up! |
275 large on 15in. rims on all 4s |
3 Attachment(s)
Attachment 671094
Instaled a Locked (clutchpack) AuburnGear diff this summer along with all new bearings, cups and seals I kept the spindels the where fine. I kept the 3.40 gears that i had, and had never heard of before (usualy GM is 3.42), the ring gear had a litle wear from used bearings but it doesnt make a peep. All in all with the diff, bearings, cups, seals, oil and gasket i spent apbout 700$ Attachment 671095 Here with the alignment paste, we can see the wear i was talking about (note the absence of paste on the bottom left side of the tooths.) But everything works great! ;) Attachment 671096 |
Attachment 671097
Things to come....soon -New eurathane suspention and body bushings all around -New shocks + Light drop -Bed cover -New brakes -H-pipe -Body work and and paint -Mags -Instal sliding rear window -Caltracs suspention -Back roll pan Future projects.... -Spay on bedliner -Heavy duty front breaks -Line lock kit -Custom interior -Custom gage cluster -5 speed tranny -Replace triangular windows on doors -Window tint -Custom front end and grill with round lights -Custom cowl hood |
wow your pictures are very nice and detailed
i just instaled my Auburn posi a week ago ! love it. got mine for 300$ new in the box
http://i995.photobucket.com/albums/a...9/bea38a5f.jpg http://i995.photobucket.com/albums/a...9/b0d65a85.jpg |
I wanna get a picture of the 3.40 stamp on the ring gear too, since its not common. If you guys have requests... just ask! |
did you count the teeth ? must be a 3:42
Any one ever heard or seen this before, i researched a bit and found nothing |
3.40 was a truck ratio 12 bolt i think may be wrong tho
http://forum.73-87chevytrucks.com/sm...p?topic=8880.0 |
Mines a 12 bolt too but didnt have a stock posi Wonder waht truck thiss diff come out of? |
Aluminum Wheels
Just fond these for sell real cheap, should be getting them by new years :D 2 8x15 and 2 9x15 Attachment 671318 GM Turbine Mags These need a little love and care, could anyone gimme a few pointers on how i could make these shine? |
PARTS SEARH
If you guys have any spare parts you wanna get rid of or sell, im looking for: -Cab Back panel molding + corner moldings -Wheel arch molding kit -2 1/2 in. drop spindels or 2 in. drop coils -Spring shackles -3 prong center caps -electric fan |
