How to install e.fan??
Hello everyone,
I have been trying to research the procedure on installing an electric fan on my 2002 silverado, but have not been lucky. My question is..... 1- Can I use the factory efan from a 05 silverado on my truck? 2- Will the efan have to be connected to the computer or will it pick up the signal from the temp. sensor and the AC relay? 3- What is your opinion about the flex-a-lite fans, and how much more does an efan increase in mpg? Your input is greatly appreciated, Thanks :metal: |
Re: How to install e.fan??
1- Yes you can use the ones from an '05, but you would also need the 34" radiator. you can pick up a set of ls1 or lt1 fans for your current setup and will work fine.
2-wire it in with a pair of relays, 1 relay per fan. you can use your own temp sensor if you buy one, doesn't need to tie into the computer 3-flex-a-lite makes very good fans, expensive though. ls1/ lt1 fans can be had for $100.00 or less |
Thanks DroppedGMC,
I'm going to look for a lt1 fan. |
i'll post some pics up for you
^^ what mine looks like
Did you notice an increase in gas mileage? Any problems with electric fans with towing?
What do you get the lt1 or ls1 fans off of. Camaro? What year? I want to do this to my tahoe.
98-02 Camaro/Firebird with a LS1 engine. The older Camaro/Firebird with a LT1 efans will also work. I'm going to try to throw a "how to" together on this when I get time.
