Can I go from 17" to 16" wheels
2 Attachment(s)
Just found a killer deal on some factory 16" aluminum wheels.
I want to replace these steel work truck 17" with them... will they fit? |
Re: Can I go from 17" to 16" wheels
They will fit.
I don't know for sure either way, but I would check the brakes first. Those are from the last body style too, not sure if the backspacing is the same???
what year is your truck? they started putting bigger brakes in '05 when they went back to drum rears.
Depends on what year your truck is. 99-04 can use 16s. In 05 they went to rear drum brakes with bigger front discs that require 17" rims.
x2 my 06 crew came stock with 17's and when i tried to put a reversed drop 17" it wouldn't clear the calipers
2 Attachment(s)
I love the look of the 20" factory wheels (found this pic somewhere surfing around), but refuse to pay $1000+ for used wheels...something good will come come up I'll just keep looking. |
Well I'll be dipped in............................:lol: I knew about the change in brakes in 05, but didn't know about the size change. |
i did on my 2000 chevy silverado and they work and look good
